Question about Exercise & Fitness
My nordic track c2050 treadmill won't fold
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
SOURCE: my nordic track treadmill won't decline
My wife had the same problem with her treadmill. I turned the beast on it's side, and unscrewed the plastic casing that houses the motor, computer, and all the electronics to the treadmill. I unplugged the incline/decline motor. Then on the bottom of the treadmill the long threaded rod that causes the incline needed to be moved. So I unbolted it from the catch, and manually screwed the rod back in with a wrench. Now the treadmill works fantastically, of course the incline/decline mechanism has been disabled, but I would rather have a treadmill with the incline disabled than have one always on 100% incline. Hope you found this helpful :)
Posted on Apr 19, 2010
SOURCE: Have a nordic track exp 1000x treadmill and the
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Posted on Oct 29, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
How do I fix a NordicTrack C2050 treadmill that has abruptly stopped?
see if you can remove the motor hood and look at the drive belt. it is a little belt from the motor to the front pulley to turn the walking belt. its either broke or fell off
Oct 21, 2014 | Nordic Track Nordictrack C2050 Treadmill...
I have a Nordic track C2050 treadmill one day everything was working great the next day the only the #1 and #7 speed button worked decline up and down stopped working plus all program buttons not work
replace the old batteries ( if your system has batteries, clean the spring contacts from oxide, corrosion, etc with contacts cleaners) put a new batteries.
2) tight and clean the ribbon cables from display board
3) tight and clean the uppers and lower connector very well.
4) adjust the REED switch, tight the connector, clean it, and test the reed for open or faulty. see the diagram attached.
Oct 25, 2013 | Nordic Track Nordictrack C2050 Treadmill...
C2050 belt does not turn
LUBE THE deck belt inmediattely, maybe you have WORN deck belt
2) LUBE the rollers bearing too
3) test the drive belt motor for worn, replace or adjust it
4) test the input voltage motor, if there are the motor need repair, See my personal TIPS.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 24, 2012 | Nordic Track Nordictrack C2050 Treadmill...
Nordic track treadmill is stuck up in space saver position
see the video and proceed , use the common sense. God bless you
Oct 07, 2012 | Nordic Track NordicTrack Treadmill, A2550
Knocking noise when the motor is running on the left side
meant the motor have being hit and u should fine a repair shop
Jun 26, 2012 | Nordic Track Nordictrack C2050 Treadmill...
How to activate my ifit
I will try to help you, the feature of software is the same. you can do it, activate your ifit. Nordic Track C2050 ACTIVATE IFIT -The Nordic Track C2050 is a treadmill that was targeted toward the budget-minded fitness enthusiast. It is a model of treadmill that is no longer being manufactured by the company. When it was still being manufactured, it developed a reputation for being an entry-level treadmill that featured a console that was easy to read because of its brightness. 1. Incline Change
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Hi, I have a NORDIC TRACK C2050. It is stuck at the full incline position. Everything else is working perfectly. I tried the reset switch with no luck. I can hear the motor when I depress the "up" arrow. I...
I am not familiar with that exact model, but it sounds like either the mechanism for lowering/raising is broken or it's off the track. Did you take it to its maximum height when this happened? If so, the teeth might be out of alignment.
Feb 24, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
11 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
