Question about Polaroid FLM-3232 Television
How do i get to user mode on my polaroid tv - Polaroid FLM-3232 Television
How do I connect my satellite laptop to my polaroid TLA04011C tv with a VGA cable
On the back of the TV there is a VGA in port !
On the remote you have to press computer key !
from page 27 of the tv user manual
http://tv.manualsonline.com/manuals/mfg/polaroid/tla04011c_tla4011tlxb.html
being an unknown model of toshiba satelite laptop the F4 key needs to be pressed to switch windows video mode to duplicate .
May 31, 2017 | Polaroid Computers & Internet
Tip
Polaroid TLA-04011C Manual Download
Polaroid TLA-04011C LCD TV Users Manual Download
Have you misplaced your Polaroid TLA-04011C LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid TLA-04011C LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________________
Polaroid TLA-04011C Service Manual Download
on Apr 30, 2010 | Televison & Video
Tip
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 26, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Where is the AV button on the remote for the Poloroid 26 Inch LCD?
Hello
I believe that you have the orginal remote control of Poloroid FXM-2611C with you, and posts this solution
There is a 'square button' on the extreme left just below the "Disp" button marked 'TV'. Repeted press of this button, you can change the input mode to TV/AV.
To select different input modes use [input] button.
You can change the inputs to various modes. Refer to its user manual for details. OK
Apr 07, 2011 | Polaroid FXM-2611C 26 in. LCD Television
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
I can't adjust the brightness on my HDTV Dolby Polaroid TV, It gives me an error message that says ''adjust only in user mode!''
this unit has presets for movie or dynamic and user settings set to user then adjust your briteness to waht you want
Sep 17, 2009 | Polaroid Televison & Video
Polaroid FLM-3732 Can not change picture settings
select picture mode.press right arrow button to change your picture mode {vivid,sport,hi bright]to change sitting you much choose user mode.the other settings are factor settings.
Dec 31, 2008 | Polaroid FLM-3732 Television
Polaroid LCD 32" TV
The user manual was no help. I called Polaroid and they help me solve the problem. Very helpful and spoke English which is unusual for customer service anymore.
Mar 29, 2008 | Polaroid FLM-323B Television
Polaroid FLM-3232 Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
