Question about Connex Radio Communications
Where can i down load a users manual for a cb 3600 hp connex radio
    Dedicated:
    Visited the website for 20 consecutive days.
  • 713 Answers
One Wire
  • 126 Answers
SOURCE: connex 3300hp radio
First off, sorry to tell you, but you can not set your swr with your radio's swr cal knob. Trust me, I own a cb shop and know what I am talking about. I have been working on cb radios for years.
You must have an inline swr meter, which can be purchased online or from a truck stop. The ones at truck stops are cheap ones, but will do the trick for the most part.
You connect your antenna 18ft coax to the antenna plug of the swr meter, and a jumper coax (any length) to the transmitter plug of the swr meter and then to the radio.
Close all doors and make sure no one is messing around with the vehicle or antenna. You must be set up as you would normally be transmitting.
Now set your cb radio to channel 40 and your swr meter to fwd. Key up your microphone and at the same time turn the set knob on the swr meter until the needle is at the line that reads set. Unkey your mic and set the the swr meter to ref. Key up again and note what your reading is. Now leave the swr meter in ref and turn the cb to channel 1. Key up and take your reading. If the reading on ch 1 is higher than ch 40 you must raise the stinger on your antenna. If ch 1 is lower than 40, you lower your stinger. You are trying to get lower than a reading of 3 and as close to 1.5 as possible. If you lower your stinger as far into the antenna as it will go and you need it shorter, you cut the bottom of your stinger no more than 1/2" at a time, and recheck your swr reading after each cut.
Once you have gotten the best reading you can, connect your antenna directly back to the radio.
The setting your swrs is to make your antenna as efficient as possible, by trying to get it as close as you can to a 50ohm impedance. THE ONLY PART OF YOUR SYSTEM THAT CAN CHANGE YOUR SWR IS YOUR ANTENNA, not your coax and not your radio.
On the swr meter, the fwd/ref switch stands for forward (power that is being transmitted out) and reflected (power that is reflected back into the radio.
Just for information sake, the swr cal switch on your radio is used to set the meter to reflect the swr that your antenna is set at. The meter on your radio is like a dummy light on your car. ONCE AGAIN, YOU CAN NOT SET YOUR SWR ON YOUR RADIO, only the antenna!!
Posted on Jan 23, 2008
informatica
  • 1114 Answers
SOURCE: Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 31, 2008
One Wire
  • 126 Answers
SOURCE: Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
bunnydawg
  • 5158 Answers
SOURCE: owners manual for connex 4600 turbo
to cut down on noise i would hook it directly to the battery. make sure there is a fuse in the power cord first.
Robert
Please rate this solution thanks
Posted on Feb 23, 2009
SOURCE: UNIDEN UH-011 UHF CB RADIO
i have just printed off a hard copy of this manual it was on Http//.www.uniden.com.au/ RESOUCES main/pdf/uh011.pdf If that isnt helpfull i could post it out to you.
Posted on Aug 09, 2009
When talking on my connex 3600 my radio sounds static on the other end
mic may be wired wrong, be wrong impedance for this radio
Apr 22, 2012 | Connex Radio Communications
Can i get a connex turbo 4400 users manual
  • Yes you can. This is actually a service manual but it covers the basics found in the users manual in the first part of the first link. Also with a service manual you can dissect the radio to perform repairs.
  • Part 2 -
http://www.cbtricks.com/radios/connex/cx_4400_cx4400hp/graphics/connex_cx4400_cx4400hp_sm_pg16_pg33.pdf
Regards, Tony
Apr 30, 2011 | Connex 4400 320-Channels Base CB Radio
How to convert a connex 3400 hp to cb radio band from 10 meter band.
That needs to be done by someone that knows how, theres soldering involved. most cb shops will do it for $free-$10.00... Don't pay any more than that.. there are no parts nor is it hard so they shouldn't charge much.
Feb 12, 2011 | Connex 3300 240-Channels Base CB Radio
Where can I find a user manual? How to work the different functions of the radio?
go to http.//raidoproshop.com/connex/connex4800dxl.htm click on contact us tell them what you need and thay will be able to help you
Dec 24, 2010 | Connex 4800-DXL 480-Channels Base CB Radio
How do you dim display lights on a connex cx 3400 hp
O the front you should have a dim switch its on of 4 up & down switches ? if not check on the back ? was it bought as a new cb or was it 2nd hand as the dimmer switch may of been used for something else
Mar 09, 2010 | Connex 3300 240-Channels Base CB Radio
Dean Pitts
Rollin CBs
Aug 26, 2008 | Connex 3300 240-Channels Base CB Radio
Owners manual
You can get the ownwers from a website called cb tricks
Jul 10, 2007 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
