Question about Southern Telecom DPH-300 Corded Phone (27-dph-300)
Dph-300 manual - Southern Telecom DPH-300 Corded Phone (27-dph-300)
I have a use d-link 50u ip phone what do i nedd to make work i don't have a manual to install
http://www.dlink.com/products/default.aspx?pid=DPH-50U&tab=3
Click on Support Resources, Pick your country and download a manual or driver, everythings there
Aug 01, 2010 | D-Link DPH-50U IP Phone
Tip
No special firewall rules needed for DPH-540 and Dlink DI-604 router
My DPH-540 works fine behind a DI-604 NAT router, without any special firewall configuration on the DI-604 (I connect to either RingCentral or SIPPhone). I hope to get another SIP phone and see if both phones can work simultaneously behind the NAT router; many web sites suggest that a different proxy port must be used (the default is 5060).
on Jan 05, 2009 | D-Link DPH-540
Tip
Configure the DPH-540 with RingCentral
To get the DPH-540 to work with RingCentral, you need to add a DigitalLine to your RC service. Then you need ignore the email sent by RingCentral which provides configuration info; instead, login to your account on the RC web site.
Click on the Preferences tab, then the "Setup Instructions" for the DigitalLine device. That should produce a popup window with info like:
SIP Domain: sip.ringcentral.com:5060
Outbound Proxy: sip.ringcentral.com:5090
User Name: 1805715xxxx
Password: yyyyyyy
Authorization ID: yyyyyyy
The password will be the same as the Authorization ID.
Configure your DPH-540 just enough so that it can obtain an IP address via DHCP. Then use a browser to configure most of the rest of the DPH-540 (user admin, password admin by default). However, the browser interface does not let you associate a SIP configuration with a profile; that must be done on the phone itself (consult the userguide and just keep at it; it's not that hard).
For an image of what the web interface and config page for a DPH-540 SIP configuration looks like, see http://homepage.mac.com/saj777/techtips/DPH-540_RC-config.jpg
Can't get the D link DPH 540 TO GET A CONNECT TO WI FI
Dear Stoneway,
First create a network profile if not yet done so
Menu > Profile > Network Profile
then edit it, go to Account Choice and select "Default".
The "No SIP Account" error most likely comes from having a blank field in "Account Choice".
It's easier to set up the DPH-540 from the web admin interface, so you can try first to at least get an IP address assigned to the phone then use that IP address to access the phone from another laptop on that same wireless network. But again by the time you manage to thumb your way to get an IP address assigned, you have 3/4 of the problem already resolved so you may as well thumb in that finishing touch :-)
Viet
Jan 24, 2009 | D-Link DPH-540
DPH-50U can't be uninstalled or reinstalled correctly
To solve a problem "device not present", you must delete registry key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{55280429-413e-460f-a31a-e19314823119}\0001" and restart service "VService".
Dec 14, 2008 | D-Link DPH-50U IP Phone
DPH-50U default audio
I had the same problem. I just reinstalled the hardware manually through the install new hardware module in XP. Once I did that, Skype "saw" the D-Link adapter.
'I went into "add new hardware" clicked "yer, hardware is already installed" then selected the D-Link device that will be listed. You have to have the driver already installed, then let the OS install the hardware as it always does and then you should see the D-Link driver as one of the choices.
This drove me crazy too. I hope this works for all of you. Good Luck.
Oct 24, 2008 | D-Link DPH-50U IP Phone
How to reset lagin password
This phone is no longer supported by D-Link, but you probably already know that by now. If you don't have a manual for the phone, you can still download it from D-Link at: ftp://ftp.dlink.com/VoIP/dph100H/Manual/dph100H_manual_100.zip
Within the manual there is a process for setting the password, presuming you can get to it.
Not a direct answer to your question, but all I have at hand right now. Hope it helps.
Dec 10, 2007 | D-Link (DPH-100H)
Southern Telecom Phone DPH-201 wired 13 memory phone
The manual doesn't seem to be available online, but you can contact the manufacturer directly: http://www.southerntelecom.com/contact.htm Here is a link to their product page for your phone: http://www.southerntelecom.com/products/cordeddph201-1.htm
Mar 25, 2007 | Southern Telecom DPH-201 Corded Phone...
Update the firmware of D-Link DPH-70s to support SIP protocol
this phones doesnt got support for standard SIP protocol, so its not supported by any major voip provider.
Jan 11, 2007 | D-Link IP PHONE DPH-70S WITH BUILT IN...
Southern Telecom DPH-300 Corded Phone (27-dph-300) Logo
16 people viewed this question
Top Southern Telecom Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Southern Telecom Lands Phone Expert? Answer questions, earn points and help others
