I have a thin black line running down my lg 55in 3d led tv model 55lm7600. The black lines start from the top right and goes to the left while fading. the lines are evenly spaced from top right to bottom left.
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
  • 458 Answers
SOURCE: my Lcd tv has a thin green line running from top
Unfortunately this is a problem with the screen & the only solution is to have it replaced. If it is still under warranty then there should not be any problem if however it is not, then it would be uneconomical to get the screen replaced as this can be very expensive.
Posted on Dec 09, 2009
SOURCE: My mom has an Emerson LCD Color Flat Screen TV
COLORS OF LCD SCREEN HAS TURNED TO PINK AND PURPLE WHAT TO DO NOW?
Posted on Jan 11, 2010
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
How to fix vertical lines on a panasonic viera 3D lcd 55" tv
Sep 01, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
I have a Samsung LED TV Model # UN60H7150AFXZA-It has a thin black horazontal line about 1/3rd up on the screen
Aug 22, 2016 | Samsung 7150 Series UN60H7150 60" LED TV...
My samsung tv has thin vertical lines of all colours on left and right of screen
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 11, 2016 | Samsung Electronics UN55EH6000 - 55in...
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
How do I replace SMART TV SCREEN MODEL NO : LG 55LM7600 55'' 3D 1080p Full HD LED LCD Smart TV
You cannot replace a screen that big. The manufacturers wont ship it to you. IT has to be done by an authorized service center.
Nov 21, 2014 | LG Televison & Video
Thin black/transparent vertical lines across the screen
If the lines aren't appear at least in one input or in smart apps then theres no posibility that the time-control is malfunctioning.the more logical is mainboard is isn't working right . could you provide me with more info and maybe a photo i'm sure I can get you a better and more advanced answer to that
Jun 23, 2014 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Mar 24, 2012 | LG 37LE5300 LED TV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
