Question about APS95BT3 Car Transmitter with 3 Button Code Hopping
Question ON Remote Start Working But not cranking engine
When I press & hold start button on remote, car ignition comes on but engine does not crank. I can physically start with key & engine will stay running for normal remote warm up time (about 7-10 minutes) and then turns off as normal.. Believe a wire became detached and need some assistance as to what wire requires to be reattached.. Thank you in advance Jim B
SENTER LOCKING TIPS
Posted on Oct 17, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 38 Answers
Is it the stock remote start or is it aftermarket
Posted on Oct 16, 2013
4 Suggested Answers
doin12volt
  • 233 Answers
SOURCE: Lights don't blink for remote start
If you look at the unit (probably installed under the dashboard, on the drivers side) You can see the wires going into the unit... Follow the wires back and you will find that 2 of them have in-line blade style fuses, it sounds like the fuse in the parking light output wire has blown. if you find the fuse is blown, replace it and the parking lights should be on again when you remote start it.
Posted on Jan 03, 2009
  • 12 Answers
SOURCE: AUDISVOX REMOTE START APS-620 WONT START AT TIMES.
i am an mecp first class certified mobile installation technician with over 10 years experience. email me at face2face11@bellsouth.net and i'll see if i can help
Posted on Jan 15, 2009
  • 32 Answers
SOURCE: I have Prestige Security Remote Start Car Alarm
where did you get it installed? what kind of car is it? unplug the brain of the security system and see if your car starts
Posted on Sep 12, 2010
Prestiege remote start only lets trunk crank for a tenth of a second
Try programming it again but don't take too long between steps..
Jul 03, 2013 | Vehicle Parts & Accessories
Aps57c can't learn tachometer
Yes, the seven flashes indicate that the system did not learn tach. Do you have the tach wire connected at the coil or an injector? If so, turn the ignition on, press and release the programming button three times, turn the ignition off. Press and hold the programming button, start the vehicle. Continue to hold the programming button. The parking light should be flashing at this time. after about 15 seconds, release the programming button, the parkings will come solid and then go off. Turn the vehicle off, the tach is now programmed. Test the system.
If the tach wire is not connected, you can program the system for tachless/voltage.
Turn the ignition on, press and release the programming button three times, turn the ignition off. Turn the ignition on,off, on, then press the programming button 5 times ( the parking lights will flash five times, press the lock button on the remote three times. This will put your setting at voltage. The setting for crank time is still set at averging so, you will have to start the vehicle four(4) times with the key so the remote starter can average the crank time.
Oct 03, 2012 | Remote Start APS57N
T & C 2001 REMOTE CONTROL PROGRAMMING
ATTENTION: You MUST HAVE one working remote to add one more to the system.
1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
go without cranking engine). Wait for ignition chimes to stop.
3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
seconds.
4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
press the PANIC button ( on the programmed remote ) for 1 second and release both
buttons. A chime will sound to indicate that the remote programming mode has been
entered ( allow 3 seconds for chime to sound ).
5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
simultaneously then press and release just the UNLOCK button on the same remote.
A chime will sound indicating the remote has been programmed. Press and release
the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
each new remote you wish to program at this time. A chime will sound afer each
additional remote is programmed.
6. Turn the ignition OFF and remove key.
7. Test Remotes.
Sep 17, 2012 | 2001 Chrysler Town & Country
I have a 2003 dodge durango i dont have a working keyless remote how do i program the one I just bought from the dealership to work?
You must have one working remote to add one more to the system.
If you do not have one working remote right now then these instructions will not work.
You will have to have a Locksmith or dealership use a computer to program the first
remote for you.
seconds.
each new remote you wish to program at this time. Locks will cycle after each additional
7. Test Remotes.
Mar 01, 2011 | 2003 Dodge Durango
How to program key fob 2003 durango
remote for you.
seconds.
7. Test Remotes.
If I've helped you, please vote!
Feb 02, 2011 | 2003 Dodge Durango
Sometimes when I press the starter button, my car with crank for a little bit, then won't start but the car is still on. I normally press the starter button again to turn off the car, then press it again....
These issues can both be solved through programming. The crank time needs to be extended and the door locks (may) need to be set to double pulse. Can you unlock the doors by pressing the unlock button twice within one second?
Please read all the way through to familiarize yourself with the process before beginning.
Let's try the programming; you will need the vehicle key and the remote. The control/programming switch is located in the antenna on the windshield.
Turn the key on then off; press and hold the control button on the antenna to select the menu. One honk of the horn/flash of the parking lights indicates menu one(1). Now, press and release the button five (5) times (door lock pulses), then press and hold the button. While holding the control button on the antenna, press the lock button on the remote once. You should hear two horn honks/flashes from the parking lights. The system is now set for double pulse unlock. DO NOT RELEASE THE CONTROL BUTTON.
We will now advance to the third menu; release the control button, immediately press and hold the control button. After three seconds the system will begin to advance to the next menu. You will hear two horn honks/flashes from the parking lights. Continue to hold the control button to advance to the third menu. You will hear three horn honks/flashes from the parking lights. Now, press and release the control button three times, then press and hold the control button. While holding the control button, press and release the lock button on the remote. You should hear two horn honks/flashes from the parking lights. Two flashes/horn honks is .8 seconds cranking time. Release control button. Turn ignition on to exit programming/learn routine. Test the system.
If after testing the system , you require a longer cranking time; re-enter the programming/learn routine, menu three, option three and press the lock button on the remote once to advance to one(1) second cranking time.
The programming/learn routine exits if the ignition is turn on, the control button is pressed too many times or there is no activity for 30 seconds.
Nov 28, 2010 | 1401 Remote Start/Keyless Entry System
How do i program 2003 dodge carvan key fob
remote for you.
Click here to find an Automotive Locksmith in your area to program this remote.
seconds.
7. Test Remotes.
Feb 05, 2010 | 2003 Dodge Grand Caravan AWD
2005 Caddy V8 sts no longer remote cranks. lights
I had the same problem with my STS. Go back through your programing menu and "check" remote start again. Somehow, mine defaulted to not allowing remote start feature. It was good to go as soon as I re-programmed it.
Nov 29, 2009 | 2005 Cadillac STS
How to program a new remote keyless entry for 2002
seconds.
7. Test Remotes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 02, 2009 | 2002 Dodge Durango
REPROGRAM THE FOB DODGE DURANGO 2004
remote for you.
seconds.
each new remote you wish to program at this time. Locks will cylce afer each additional
7. Test Remotes.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 09, 2009 | 2004 Dodge Durango
APS95BT3 Car Transmitter with 3 Button Code Hopping Logo
74 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
