Question about InFocus Work Big IN10 DLP Projector
Infocus IN10 projector, when I turn it on the light blinks green for a while (with no picture) and then it shuts off and blinks red (more than 5 blinks)
  • 36 Answers
If Lamp or projector shuts off after running a short period of time, This is usually a thermal issue caused by excessively
high internal temperature. The high temperature
could cause a component on the controller ECA or
the power supply to fail when it gets hot.
First you need to check the fan operation, Are 3 fans, two for lamp and one for the color wheel. Check the elevation foot, if something is broke maybe something stop the fan.
Remove the lamp module.
Examine the fan assembly through the recess in the bottom case. Plug the projector in and turn it
on. Both fans in the fan assembly should start up and run for 5 - 10 seconds, then shut down
(because there is no lamp installed). This is time enough to make sure the fans work properly.
Make the same for the color wheel fan, you need to remove the top case.
Posted on Nov 07, 2013
SOURCE: Projector powers on but no picture.
depends on how many times the orange light blinks also when you replaced the lamp did you do a timer reset? you can find alot of information on how to trouble shoot this www.infocus.com/support
Posted on Sep 12, 2007
cammykins
  • 149 Answers
SOURCE: infocus sreenplay projector
Contact the manufacturer for a firm ware upgrade. My two brother in laws/sisters own this same pj and had the same issues you are talking about. Once they installed the update [aka: firmware upgrade]it created a solution to the problem.
Let me know how it goes. They can either mail you a CD, direct you to where on their website, otherwise email you the update to download. You have to connect your pj as well.
Let me know how that goes. I'm fairly confident that will fix it. There was a certain time frame [manufacturer dates], and serial numbers that had these issues.
Posted on Oct 27, 2008
projdoc
  • 2237 Answers
SOURCE: Infocus X1a no picture, solid green LED
if the lamp is new, it could be the power supply (the ballast is built in to the ps). but make sure you have the right lamp. the X1 and X1a have an sp-lamp-019 and the similar X2 and X3 have an sp-lamp-018. the lamps are almost identical except for the wire configuration on the lamp plug. make sure the wires in the plug match the positions in the socket. also, when you turn it on, if you don't hear a high pitch squeal, the colorwheel is not working. and if that isn't working, the lamp won't either. also check to see if the lamp door is closing properly and hitting the switch at the top of the opening.
Posted on Jul 15, 2009
projdoc
  • 2237 Answers
SOURCE: LP70 Infocus Projector light will not start up
if you don't hear a high-pitched whir, the colorwheel needs to be replaced. if you do, it's either the lamp or ballast. if the lamp is new, replace the ballast. you can get the parts if you want to do it yourself, or you'll have to send it in. either way, try av solutions in ny. they are an infocus service center and they're really good. www.avsolutionsny.com
Posted on Nov 25, 2009
  • 269 Answers
SOURCE: Infocus IN10 projector is flickering
it is likely a grounding problem associated with the connection of the power supply to the main board.
Posted on Jun 20, 2010
Infocus in104 projetor problem: power off, temp red, lamp green
Most probably failure of the thermistor or thermal fuse that detects the temperature of the lamp housing - so the projector thinks it's hot even when it's cold. Unfortunately it will need a trip to an authorised service centre for repairs
Apr 04, 2014 | InFocus IN104 Projector
Jun 08, 2010 | InFocus LP70+ Multimedia Projector
Replaced bulb. Worked for a while then wouldnt power up again.
the cheew cheew cheew is the colorwheel not spinning properly. either the colorwheel motor is shot, the sensor can't sense it, or the power to it is too low. first thing: remove the cover and blow the dust out of it with canned air. dust does a lot of damage to these. if it is the sensor, cleaning it off might help. if it is the colorwheel, i have bad news: on the x1, the colorwheel is not sold seperately from the optical engine. you'd have to get the entire optical engine. now the worse news: infocus no longer makes or sells parts for the x1. you could try and find one on ebay that has a different problem and swap out the parts
Dec 29, 2009 | InFocus X1 Multimedia Projector
Infocus X3, no light, LED is solid green.
the colorwheel. if it does not spin, the lamp will not light.
Aug 26, 2009 | InFocus Proxima UltraLight X350 Multimedia...
I have infocus sp5000 and the lamp has stopped working. I pulled it our of the unit and it looks perfect. I suspect it is the lamp counter, but I need a method to reset without being able to see the...
there isn't one. you need to see the menu. but what color is the led and is it blinking?
green- all is well
red blinking:
1 time- lamp not striking after 5x.
2 times- lamp has more than 3000 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fan failure. shuts down.
5 times- undiagnosed error. possibly ballast or colorwheel.
if the colorwheel won't spin, the lamp won't light. when you turn on the projector, do you hear a high-pitched whir? if not, the colorwheel needs replacing.
Aug 17, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus Work Big IN10 DLP Projector Logo
237 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
