Question about APS95BT3 Car Transmitter with 3 Button Code Hopping
Reset autopage When I press remote start button car ignition comes on but will not crank. Believe a critical wire came detached? Wondering if you could point me in proper direction for correcting this? Thank you
    Sergeant:
  • 206 Answers
Hi
every alarm is different i would take the car back to the installer
i wouldn't play around with the wires because you dont want to short circuit the wires and cause a fire
it sounds like the power wire to one of the accessory wires is off or the coil wire is off
but you will have to test each wire and the relay
a multi meter or test lamp will be fine
but be careful not to shorten out any wires as it can cause a fire
aries
Posted on Oct 19, 2013
Aps57c can't learn tachometer
Yes, the seven flashes indicate that the system did not learn tach. Do you have the tach wire connected at the coil or an injector? If so, turn the ignition on, press and release the programming button three times, turn the ignition off. Press and hold the programming button, start the vehicle. Continue to hold the programming button. The parking light should be flashing at this time. after about 15 seconds, release the programming button, the parkings will come solid and then go off. Turn the vehicle off, the tach is now programmed. Test the system.
If the tach wire is not connected, you can program the system for tachless/voltage.
Turn the ignition on, press and release the programming button three times, turn the ignition off. Turn the ignition on,off, on, then press the programming button 5 times ( the parking lights will flash five times, press the lock button on the remote three times. This will put your setting at voltage. The setting for crank time is still set at averging so, you will have to start the vehicle four(4) times with the key so the remote starter can average the crank time.
Oct 03, 2012 | Remote Start APS57N
Somehow buttons seem to have been pressed on my remote and now there are 3 "z"'s that have appeared on the remote and I have no idea how to get rid of it. My remote now doesn't make a...
Turn ignition on, hold the red valet switch down for 2 seconds. Then turn ignition off. Your system is in VALET mode.
The remote start and alarm system will not work when in valet.
Aug 06, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
Just purchased a remote on the internet need to know how to program it to my car alarm
turn ignition switch to ON 3 times, leaving it in the ON position the 3rd time. Press the RED VALET button installed under your dash somewhere, 2 times (holding on the 2 nd push) you will here the horn honk, release valet switch, and then press the LOCK button on the new remote. The horn will honk if it programs. Turn ignition off and the horn will honk 3 times to let you know it exited the programming sequence.
Jul 23, 2010 | C3RS603 2Channel Remote Start Module with...
Program remote
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal.
Jul 09, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
Remote says OUT OF RANGE when i try to arm it.
Reprogram the remotes using this procedure:
Enter:
Program:
May 07, 2010 | Megatronix - TW71 - 5 Button 2 Way LCD...
After installing a rs1100 remote starter the vehicle keeps giving several error codes (which I reset but they keep coming back). I'm not sure if the ignition (white) and the starter crank (orange w/black)...
IF YOUR REMOTE STARTER IS CLICKING AND/OR FLASHING THE PARKING LIGHTS AND IS NOT RESPONDING TO THE REMOTE, IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
If you have a 4 button remote, you must ground the black/blue hood pin wire (raise hood if hood switch is installed). Apply 12volts to blue/black brake wire (press and hold brake pedal if wire is installed). Press and hold any button on your remote until clicking and flashing stops. Unit will now respond to the remote. Remove ground from hood pin wire and voltage from brake wire. If you have a 2 button remote, hold brake and press any button on the remote until clicking and flashing stops.
Other details can find in the Bulldogsecurity ModelsRS1100_1100E_114
TY for use Fixya, good luck(remember rated this help).
Mar 02, 2010 | Remote Starter with Keyless Entry
APS95BT3 Car Transmitter with 3 Button Code Hopping Logo
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
