Question about Frigidaire Refrigerators
Fridgeaire Model# FFHS2313LM3...... Refrigerator
Fridgeaire Model# FFHS2313LM3...... Refrigerator beeps occasionally and the temp on both sides has risen tremendously......Any clue as to what the problem is.......Purchased it brand new in May of 2012.......
  • 3 Answers
Had a beeping fridge. Nearly went crazy. Then worked it out. The button that getts pushed in when the door closes and turns off the light was not engaging when the door was closed. I taped it down. The light does not work but no more beeping. Nearly dumped the fridge.
Posted on Oct 21, 2013
machinetech7
  • 1344 Answers
SOURCE: sub zero 642 refrigerator not cooling
Being a sub zero tech and actually fixing that exact model earlier today I would recommend you call a qualified service tech to come take a look. If not, I'll tell you the steps I would take to isolate the problem. 1) check to see if the refrigerator fan, also called the evaporator fan, is running. Just open the door, hold in the switch next to the light switch and listen. You'll hear it easily if it is. 2) If fan is running remove the grate up top, the one you took off to put the condensor fan motor, and see if the right side compressor is running. Don't always go with if its vibrating its running because the freezer compressor or the condensor fan can cause it to happen. Find the high side, or condensor line which is the smaller that comes out of the compressor in the back and runs up front to the condensor, and feel if its hot. Hot = good, cold = bad. Note that all this can be avoided if you have a set of freon guages because that model has access taps already on them. They are wrapped in yellow. If you have guages unscrew the cap and connect the guages. On the outside numbers the needle should be around the 25-30 on the positive side. If its in the green area, the negative, around the 10 you need some freon, and possibly have a micro-leak that needs repairing. If its down in the -20 to -30 area you have a serious leak, more than likely in the evaporator inside the fridge, and you should relay call a tech. Now if the needle jumps way up to 70 or 80 and the compressor is hot, really bad, call tech. and if it does that and is cold, the compressor is just off. Now if your still with me and stuck through this far i'll give you the cliff notes.
If the temp is 55 that mean the fan inside is running, and that more than likely the compressor. Now here are some questions to ask yourself. Are the condensor coils clean? That would raise the temperature. You just changed the condensor fan motor, did you put the blade back on right? If the air flow is blowing across the compressor in the direction of the freezedr compressor, your blowing really hot air from the condensor across the compressor and your temperature will raise badly. Fan draws air across the compressor and through the condensor. Worse case scenario you jacked the control board up inside, which I dont think is the case either. ** check that fan blade **
Posted on Apr 29, 2012
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
  • 33 Answers
SOURCE: Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Posted on Nov 29, 2008
  • 5 Answers
SOURCE: Fridgidaire refrigerator freezing
close the baffle that blows air onto the top shelf a bit.
Or you have a bad thermostat or thermistor- if it's a didital type temp cuicuit
Posted on Oct 26, 2007
  • 137 Answers
SOURCE: I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
Posted on Nov 28, 2009
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Mar 26, 2016 | Kenmore Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 11, 2015 | Frigidaire Refrigerators
The refrigerator makes 6 beeps after dispensing water. Everything seems to be working normally so I do not understand why it beeps after the paddle returns to its normal position.
Apr 05, 2015 | Refrigerators
How do you get the model 370lb to stopping beeping
Mar 30, 2015 | Refrigerators
Flap won't stop humming buzzing
Oct 07, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
89 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
