Question about Brother ML-100 Typewriter
I have ordered 3 ribbons and I get them to work
    Champion:
  • 204 Answers
Follow the is link for the manual..........
Posted on Jan 23, 2014
My printer is a Sony color printer up-51md and it is saying that the color ribbon is 0 but I have put in a new ribbon and it still won't print, help please!
Follow these steps to see if the problem can be resolved.
1.) Turn the printer off.
2.) Unplug the printer from the power source.
3.) Wait 5 minutes.
4.) Remove the ribbon.
5.) Reinstall the ribbon.
6.) Reconnect the printer to the power supply.
7.) Turn the printer on.
These steps assume that you can replace the ribbon with the printer off, if you cannot, follow the steps in this order: 1,2,3,6,7,4,5
Please let me know.
Dec 17, 2015 | Sony UP 51 MDS Printer
How to disassemble the Samsung brightside cell phone
Don't know if you were able to get this done but I needed to take apart the lcd screen on mine and replace it. in order to get to it you need to start from the back and work your way up to the front.
Tools:
-preferably a #000 philips screwdriver
-not necessary but I also used a 3/64 flathead screwdriver
1. Take battery cover off.
2. Take out battery
3. Take the #000 phillips screwdriver to take out the six silver screws.
4. Now take out the two black screws that were behind the battery.
5. Slide the phone out now in order to get better leverage to take off the plastic case that protects the circuit board.
6. Now there will be a ribbon cable connected to the circuit board. just pull it off. The cable actually snaps on so all you need to do is pull it off, there is not a locking mechanism for this.
7. you can now take the circuit board off to see the back side of the qwerty board and the slider. remove all of the silver screws on the slider.
8. Now the slider can come off, to make it easier, take off the ribbon cable that is fed through a slot on the slider. The ribbon cable is connected to a square, the square is stuck to the plastic piece by tape and will not hurt anything as you pull it off. Once that is off you can now fee the cable out of the plastic piece that was connected to the slider in order to get it out of the way.
9. Now there are 4 black screws on the back of the lcd cover. take them out.
10. This is stuck on pretty good and I had to use a small flathead screwdriver (I used a 3/64 flathead) and a lot of fandangling to get this piece off.
editor's note: I replaced the lcd so I'll just explain how to do that. I don't know if you needed the window replaced or if it was the lcd.
11. From this point the ribbon cable's port is blocked by a bluish tape. peel that off, and you should be able to see the locking mechanism which is a black bar on the opposite side of the ribbon cable. lift this black plastic bar up and the cable will pull right out. There are two other ribbon cable's on the left side of this port where you will need to do the same thing. These two other ports have the same locking bar so make sure to lift it up before taking the cable out.
12. Last step, the lcd screen is not connected but stuck to the bottom by a tape or some sticky substance. I took my flathead screwdriver and just peeled it off.
13. That was the last step, should be self explanatory from here, just work your way back and make sure all those ribbon cables are snug. I hope this helps, I noticed no one had made a video or made any responses from what I could see toward this subject so after successfully doing this I hoped I'd be able to do someone some good. Peace!
Jun 13, 2012 | Samsung Brightside U380 Smartphone Verizon
I broken the plastic blue ray ribbon connector on my motherboard
unless you can find a great tech near you to repair the ribbon ( extrem hard to do but can be done ) call sony and order a new ribbon link cable
Jun 18, 2010 | Sony PlayStation 3 40GB System
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Iphone wont turn on after eplacing screen
Hold both the home and power button together for 10 seconds, it should at least give you an apple, if nothing then your iphone is gonna need some work...
Sep 17, 2009 | Apple iPhone Smartphone
Keyboard problem. Key 3, @, #, y, n can't use
you may have shorted your keyboard (spillage??)
if your laptop is outside warranty you can check the connection to the keyboard, by removing the top bezel, undoing the keyboard retaining screws and then check that the ribbon cable for your keyboard is seated properly, If reseating this cable does not work the you can always order a replacement for your keyboard, you can find the part number for the keyboard you have, it should be printed on a tag on the reverse of the keyboard.
May 24, 2009 | Acer Aspire 3680 Laptop
Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Mar 27, 2009 | Datacard SP35 Printer
RIBBON ERRORS
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
Mar 02, 2009 | Toshiba TEC BSX5 Thermal Label Printer
IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Sep 22, 2008 | Lexmark Wheelwriter 3 Typewriter
Brother ML-100 Typewriter Logo
35 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
