Question about HP Media Center M370N (DM163A#ABA) PC Desktop
PC m370n won't reboot
Installed a Graphics card EVGA 6200 AGP 8X in my PC HP Media Center PC m370n now keeps showing failure notice
Did you install the drivers for the Graphics Card before you plugged the card into the computer? If not, remove the graphics card and reboot using your old video connection, install the driver then install the card and plug your monitor into the newly installed card. If you still have an issue try booting into safe mode.
Mar 19, 2012 | HP Media Center Photosmart PC (M7160N) PC...
Media center m370n keeps rebooting in loop wont start says KERNEL32.DLL was not found
Sounds like you have a boot error on the hard drive. Time to get out your rescue discs and reload Windows. When reloaded run CHKDSK/F to clear any errors. If you can run CHKDSK/F before having to format your hard drive, that may save you a lot of time.
Feb 05, 2011 | HP Media Center M370N (DM163A#ABA) PC...
Need drivers for TV-Tuner - HP Media Center PC m370N
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-20048-1&lc=en&dlc=en&cc=us&os=228&product=367282&sw_lang= is the driver you need
Dec 12, 2010 | HP Media Center M370N (DM163A#ABA) PC...
I need a cpu fan for the HP Media M370N
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150086 this is a compatible cpu fan and heatsink or you can search ebay and find the oem fan and heatsink quite easily
Sep 23, 2010 | HP Media Center M370N (DM163A#ABA) PC...
I had to change the motherboard as it failed
Look at the front panel of the computer you will see the connections you have. Should be power, reset, power led, usb etc. These are connected to your current motherboard and most times all the connections will be labeled in the case, on the wire connector ends. IE the end that connects to the motherboard. The only exception to this is the usb ports, and they can be hooked up to new usb connectors on the motherboard. Also note, read i said READ the proper way to connect the usb to the motherboard, this is usually a one shot deal, get it wrong and you kill that usb connector.
Apr 24, 2010 | HP Media Center M370N (DM163A#ABA) PC...
I am unable to getthe tv and radio to work through
check the drivers and check that Media Center settings are optimized
Mar 08, 2010 | HP Media Center M370N (DM163A#ABA) PC...
I have an HP media center pc the m370n, and i just upgraded to windows 7 ultimate. I can not get the tv tuner to work, what could be wrong? thanks. Ryan
think you'll find the drivers for the tuner are not compatible with windows 7. according to the hp website this is an xp machine. download the windows 7 compatibility checker from here to check http://www.microsoft.com/downloads/details.aspx?familyid=1B544E90-7659-4BD9-9E51-2497C146AF15&displaylang=en
Oct 14, 2009 | HP Media Center M370N (DM163A#ABA) PC...
Cpu fan error on monitor. Fan still spins. Replacement fan generates same error
try going into ur BIOS and select load failsafe defaults...save and exit and it should be fine...if it works LEAVE UR BIOS ALONE...
May 27, 2009 | HP Media Center M370N (DM163A#ABA) PC...
Need to replace the power supply on a m370n hp pavillon
A normal ATX power supply will work for your system. When purchasing make sure it is an ATX style psu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | HP Media Center M370N (DM163A#ABA) PC...
Main fan at power is making a wierd noise
IF IT THE POWER SUPPLY FAN YES I WOULD REPLACE ASAP.RICHARDM69
Dec 02, 2008 | HP Media Center M370N (DM163A#ABA) PC...
HP Media Center M370N (DM163A#ABA) PC Desktop Logo
13 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
