Question about Whirlpool GEW9868K Electric Dryer
The panel lights are on but it wont turn on and clicks and says sensing
  • 119 Answers
Sounds like one of the relay on the main board is bad. some models have heater relay and motor relay off the board, you might want to take a look, if it is, swap the relays. if it runs but no heat, then you have a bad relay. if its on the board itself, you can probably replace the relay if you know how to solder and can find the relay locally or online. or just buy the new board
Posted on Oct 16, 2013
WTW4850XQ spins for a few seconds, then quits
Place the unit in diagnostic to do this make sure machine is off turn control knob to the left at least 3 times to clear now turn knob 3 clicks to the right 1 left 1 right all lights should light up do this within 6 seconds if you don't get lights repeat process I do this everyday so be patience once all lights are lit turn to the right until done light is lit press start button you will now see lights flash in varying sequence the way to read this the lit fill/sense light is the f code, wash light =8, rinse =4, spin=2, done=l when fill/sense light is not lit this is the second halve of the code example F7E1 you would have fill/sense lit, rinse=4, spin=2,done=1 F7 code, non lit fill/sense done=1 okay you may have more than 1 code it will continue to read the same code until you turn the knob once to the right the control will hold up to 4 codes at a time once you find the codes we'll go from there
Feb 04, 2014 | Whirlpool Washing Machines
After pushing start, lid locking light flashes, clicks like it is locking but is not locked and nothing happens but it keeps clicking
Sounds like the lid lock itself is bad, be sure to check the connections at the control board. There should be a tech sheet inside the front panel towards the top left. This can help you check the error codes and wiring diagrams.
Dec 01, 2017 | Maytag Centennial MTW5800TW Top Load...
Interior light delay not working
That is normal operation, as long as the door is open the door ajar switch senses that and keeps the interior light(s) on.
Sep 06, 2017 | 2010 Chrysler Town and Country
I have a fully loaded Trofeo. The dash lights won't work and it doesn't appear to be any fuses. The headlights have the auto sensing for darkness and auto on and I believe the instrument panel lights are...
To the left of the panel there is a little button that will move vertically. push that all the way up, just before it clicks (the click will turn all interior lights on). If that doesn't work there is a fuse in the glove compartment. i don't have my manual on me but there is a cluster that has instrument panel lighting on it. it usually says IP cluster or something. or have a mechanic go into service mode. I could tell you how to do that but it's kind of confusing without showing you
Feb 05, 2011 | 1992 Oldsmobile Toronado
2001 chevy cavalier,cooling fan wont come on,relay o.k,temp sensor o.k,coolant level o.k.,chec engine light on,also trac light on,also a/c compressor clicking on and off,code reader says cooling circut...
could be a p.c.m. if you can't read codes.
Engine light if giving a cooling circuit problem, senses that the fan won't come on. Trac goes on when the abs wheel speed sensors don't sense right speed (open or closed circiuit). Could be a fusible link near starter.
a/c clicking on and off, could mean charge is insufficient or too much r134a in the system.
Those are my thoughts on it.
Jul 22, 2010 | Chevrolet Cavalier Cars & Trucks
Televison wont turn on but red light flashing and
You can't fix it yourself, it needs professional.
Jan 14, 2010 | Televison & Video
The sensing light comes on ,clicks, nothing happens
the sensing light comes on, I hear a click but nothing happens.
Dec 12, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer wont turn on
Ours was doing the same thing you would hear a click and nothing but the sensing light. I found the thermal fuse to be blown Part #3392519. Easy to get to through the front cover under the load door. I went ahead and vacuumed and cleaned out the inside and vent tube.
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Appril air 600 wont work
the change water panel light is just a timer. it does not sense that the water panel actually needs to be replaced. sounds like you have a solenoid issue. if you have water to the solenoid and are certain you are getting 24v to it, the solenoid is ethier bad or plugged with calcium. most likely calcium. sometimes you can take them apart and clean them. so, it you can hear clicking at the solenoid when you turn the humidstat up and down. try cleaning it.
Jan 14, 2009 | Aprilaire 600 Humidifier
Whirlpool GEW9868K Electric Dryer Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
