Question about Roper Dryers
Where are sensor strips located on a Roper Dryer?
  • 119 Answers
If they have it, it should be inside the tumbler. if you look inside the tumbler, usually on bottom as you put your head into the tumbler
Posted on Oct 16, 2013
Roper model red4640yq1 heats in auto mode but not on timed dry
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Feb 26, 2016 | Roper Dryers
Duet gas dryer only drys on timed
One thing you can do is clean the sensor strips located inside the dryer. Get some windex and clean the coating off them. Dryer sheets rub against the strips and form a barrier. The machine THINKS the clothes must be dry because it ain't SENSING dampness from wet cloths rubbing against them sensors.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
RES7648KQ0 Roper dryer takes for ever to dry on auto but works fine on timed lowest setting. I'm thinking the moisture sensor. I found the location of the sensor for a front lint trap, but this is a...
See that white skinny component by the blower? That is the thermal fuse
Below it is the control T-stat. Now when that filter housing is clogged
The temps rise considerably faster. This control turns the heating element on and off during the drying session. So if you have this:
The autodry feature is not gonna work so good. Why?
See that orange wire attached to the high limit thermostat?
That feeds power to the timer motor if the heater element is not on.
Bad control thermostat AND/OR air restrictions are the Autodry type dryer's worst enemy.
Try first cleaning the dryer and see if that makes a difference.
If it still has problems then change out the control thermostat.
Videos and service manual is HERE
Aug 10, 2011 | Roper Dryers
Dryer works but has no heat. Voltage is good. Could it be the TCO?
I suspect that your heater strips in the dryer have burned out. Just to give you an idea, I have replaced my heater strips in my 40+ year Whirlpool dryer two additional times over the years. You will have to take the back off of the dryer after disconnection the 220V plug and examine the heater strips.
Nov 30, 2010 | Roper Dryers
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Moisture sensor not working
No parts needed for this repair! Get a warm damp cloth and reach inside the rear of the dryer and clean the **** off the 2 strips of metal in the back called sensors. Next get the rear of the timer panel off and yank out the small computer board next to the timer. This is the moisture sensing board. Get some alcohol and clean the copper contacts. Shove the board back in and retry.
Jul 14, 2008 | Roper REX4634KQ Electric Dryer
Roper dryer again
if its a thermal fuse located on rear bulkhead of dryer, youll find it by removing back cover of dryer, little white thermo,if bad there will be no continuity through it
Feb 24, 2008 | Roper REX4634KQ Electric Dryer
Roper gas dryer not heating
the glow plug (ignitor)must draw 3 amps or more to function properly if its ok check the flame sensor for continuity located on the side of the burner housing and if its ok then the gas coils on the top of the gas valve are faulty let me know if this helps
Sep 11, 2007 | Kenmore 74962 Gas Dryer
Dryers Logo
105 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
