Question about Makita 9404 4'' x 24'' Belt Sander
Belt not moving roller is - Makita 9404 4'' x 24'' Belt Sander
Makita planer 2012NB belt replacement
Use dish washing liquid to lubricate the roller and belt on both rollers and place the belt equally on each roller and move in on both rollers evenly
Feb 15, 2013 | Makita 2012NB Electric Planers
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
Rollers not moving
A careful inspection is likely to reveal the belt that moves the rollers is broken or the rollers are jammed up with hair or fiber and cannot move---the jammed up issue usually requires no real tools but the belt will require that are where the rollers are to be opened up to get at the belt which usually slips on the shaft from a motor---tight fit.
Dec 17, 2012 | Kenmore 23313 Whispertone Bagged Canister...
The brush turns very little and can be totally stopped or not moving. If it does move it can be easily stopped with a finger. I checked the belt and it seems to be fine.
Hi learnspirit...
Either you belt has streached or you roller has worn down causing this problem...
I would replace the belt...it is cheaper
Please rate me
Jul 23, 2011 | Dirt Devil Accucharge Stick Vacuum
I accidentally got a piece of string wound around the brush roller. It stopped the roller. I unwound and removed the string the but the roller is not rotating. Is there a reset button on a hoover tempo...
You could have broke the belt of the vacuum or it could have fallen off. Find the belt and evaluate the condition of it and if it is on track.
Please rate this post. Thank you!
Jun 10, 2011 | Vacuums
When I power up my treadmil the belt does not move. If I step on the side the belt would then start to move until I move my foot.
In order of most likely cause. 1) Worn motor belt needs to be changed. Rear roller bolts need to be tightened as the walking belt has too much slack(2-3 inches lift on the edge of the belt in the middle on each side) 3) the nylon pulley on the front roller is slipping and a new roller is needed.
Oct 03, 2010 | Reebok 8050 ES Treadmill
Belt stops when I get on it
This will require a new front roller. The drive belt is usually fine when this happens. Just the roller and the plastic pulley have seperated.
Good Luck Tim
Dec 17, 2009 | Proform Exercise & Fitness
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
May 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
Roller not moving
You can buy a new vacuum at walmart.
Feb 28, 2008 | Vacuums
Makita 9404 4'' x 24'' Belt Sander Logo
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
