Question about Refrigerators
Amana side szd25ne
Condensation drips on the corner of the fridge side door
SOURCE: Dripping water inside
At the back of the refrigerator, you will find a evaporation tray, unscrew it and empty it.
Posted on Sep 06, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 28 Answers
SOURCE: Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
Posted on May 09, 2009
  • 52 Answers
SOURCE: Side by side Amana freezer/fridge. When you close
Possibly need the hinges adjusted.
Posted on Jul 15, 2009
SOURCE: amana SBDE520N
HELLO, MY NAME IS TZINAS JOHN FROM GREECE AND I HAVE A PROBLEM WITH THE WRITE DOOR OF MY FREEZE.
THE MODEL IS * SBDE520S W *
THE PROBLEM IS THAT IT GET IT ALL THE DOOR DOWN FROM THE DOWN SIDE OF THIS.
I HAVE FIND THAT THE PROBLEM IS TO A LITLE PLASTIC PEASE FROM THE DOWN SIDE OF THE DOOR.
PLEASE CAN HELP ME WHERE I CAN FIND THIS PART???
Posted on Jul 25, 2009
Whirlpool side by side full drip pan
The condenser fan should be running whenever the compresser is running. With all of that condensate, I would look at your door gaskets. If they are leaking and you are in a high humidity area you will produce more condensate than what the pan can Handel. Then again. If the compresser is running the heat from the discharge line should evaporate the water with ease. I would look at the seals possibly leaking and ignore the full drain pan.
Sep 08, 2012 | Whirlpool Refrigerators
Amana SZDE27MPE
check the gasket fist if it's ok check the closure.there's a door closure on the bottom of the door and hinge that wears out and needs to be replaced,is the fridge door when closed side by side lower than the freezer door?it's plastic,here's a picture
http://www.repairclinic.com/PartDetail/Closing-Cam/R0181181/1035
part number R0181181 but call your local parts store and give them your model and p number or manufactures number and they will sell you the correct part,on some kits they give you the cams,shims and new screws,as for the drip pan overflowing,this is most likely from the warm air getting into the fridge melting out the frost on the coil or ice,usually when this happens the air ducts freeze up and the fridge section gets warm because the dold air from the freezer can't blow over into the fridge side because the air ducts are filled with ice,shut down the machine or unplug it,remove everything from the door,remove the top screws and then tilt out the door and lift up,put the door on it's side and change out the cams,it's usually a 5/16 inch screw holding them in place and then put it back together,while you have the door out check the gasket,any rips or anything change it out.hope this helps and good luck.
Aug 27, 2012 | Amana Refrigerators
SQD26VL side-by-side has a fishy odor. Where is drip pan?
The drip pan is outside the fridge I believe, sitting in the back panel.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
Oct 08, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
Jun 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore upright fridge--freezer door drips when cleaning
Condensation has formed and frozen behing the door panel. You can live with it, or take apart the panel and dry it out - you may have to replace some insulation. Hope this helps!
Feb 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Amana AB2225pekw
One of your doors is not closing all the way allowing warm air into the fridge causing condensation.
Sep 30, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
