Question about Maytag MGR6875BK Gas Kitchen Range
Keeps tripping circuit breaker everytime on plug the power cord in
Popping sound from my stove top on my Maytag MGR6875 Double range oven. Will not stay on. will trip the circuit breaker every time I plug power cord in outlet.
  • 81 Answers
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Posted on May 07, 2009
Maytag gemini range
Don't keep resetting the breaker, you have a dead short and you could burn your house down, call an electrician.
Jul 22, 2016 | Maytag Gemini 30" Self-Cleaning...
No problem with hotpoint electric range til I went to start oven, breaker kept tripping & making a popping noise
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
When I connected my oven to the electrical connection, the circut breaker keeps tripping. What can be wrong??
do you have a 50 amp double pole breaker for the stove ! it should be. if yes and it still blows, there may be a cord problem and it needs replaced.
Feb 09, 2012 | Thermador PRDS366US Dual Fuel (Electric...
Spectra profile performance jb960k0d1cc has power but neither oven and stove work
what type of power cord does your range have? is it a three prong cord or a four pronge cord. If it is a four pronge cord you must make sure that the ground wire is attached correctly on the back of the range. You can refere to your owners manual that came with the range on how to hook up the range cord.
Nov 14, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The stove made a popping sound and the circuit breaker popped.i reset the breaker and it popped instantly.
Since you have a gas kitchen range, finding the problem should not be that difficult.
1. Make sure all switches are in the off position. Then reset the circuit breaker. If it didn't trip, then turn one knob on at a time (and then off) until it trips.
2. If the circuit breaker triped with all knobs off, then it would have to be something that is always on like the 12V transformer.
Hopefully, this wiring diagram will be of help.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Range-Parts/Model-MGR6772BDS/3048/0124002/M0604023/00009
Jun 23, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag stove mer6769baq trips the breaker whenever plugged in
It sounds to me like there is a short circuit either in the plug or the connections at the stove. It could also be within the stove although that seems very unlikely. If this happens when your using the stove, the breaker and circuit could be undersized (required breaker size-50AMPS) Check all wires and the breaker.
Apr 01, 2009 | Maytag MER6769 Gemini Electric Kitchen...
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven fuse blows - Nothing works
try lifting the stove top assy and checking wires under main top, leading to the elements them selves??? if tis tripping and not allowing to reset its gotta be an obvious short. isit hard wired directly to stove or into a 220 cord and plug???id look again, perhaps remove entire back panel and have someone trip on the breaker you might see where it flashes as it trips off
Apr 03, 2008 | Tappan TEF242 Electric Kitchen Range
Maytag MGR6875BK Gas Kitchen Range Logo
975 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
