Question about Magic Chef 31000 Gas Kitchen Range
The oven door handle is broken on a Chateau by Magic Chef for a 1969 Mobile Home gas range/oven combo. Need help locating the correct part.
  • 1314 Answers
SOURCE: Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Posted on Jan 21, 2008
aborcass
  • 2651 Answers
SOURCE: trying to find model number of an old Magic chef gas oven
depending on age, sometimes on back, or even under the main top if it lifts up, sounds as uf you would need to replace the door hinges
Posted on Nov 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Broken glass in oven door
The inner glass panels are still available and replaceable.
Cost about $45.00
Posted on Mar 09, 2009
localwonder
  • 6784 Answers
SOURCE: Magic chef gas range repeated F1 and F3 error
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Posted on Nov 25, 2009
  • 119 Answers
SOURCE: Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Posted on Feb 14, 2010
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
Where would I look to get replacement broiler element for an electric Magic Chef Chateau over and under oven model 251v-2cw. It's in great shape other than just blowing this element.
Is the model number listed 251v-2CW that of the Oven or the part # of the element? That number is not showing up as either as a proper model #. Can you double check the Oven's Model # and list the Serial Number as well?
Dec 27, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Trying to find model number of an old Magic chef gas oven
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
I have a 1948 Magic chef gas oven.Model # 8620. The gas was turned off at my home and the pilot light on the oven went out. The gas is now on and I need to relight the pilot light. I am not sure on the ove...
You did say 1948, as in 60 year old range?
Well, gas ranges did not have fancy safety valves or things like that back then. Most likely when you turn on the gas, a small amount of gas begins escaping at the pilot orifice. Then use a long handled lighter to put a flame there. Pilot should light right away.
Oct 11, 2008 | Magic Chef Kitchen Ranges
My magic chef over the range microwave oven handle is broken, i ordered the part online and have received the same. However I do no know how to remove the old broken handle and replace it with the new...
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 01, 2008 | Magic Chef Microwave Ovens
Microwave oven not functioning
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Dec 04, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef 31000 Gas Kitchen Range Logo
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
