Cooktops Logo
A
Anonymous Posted on Oct 15, 2013
We have an Electrolux EW30CC55GS induction cooktop that has been in storage for 3-years, and never used. Upon completion of our renovated kitchen, the cooktop was installed. We immediately received the error code "E" with no other numbers associated. How has this been fixed in other similar instances?
3 Related Answers
Anonymous
  • Posted on Jul 16, 2010
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Anonymous
  • Posted on Dec 21, 2010
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Aug 29, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: Electrolux Induction Cooktop E36IC75FSS Error Code 41
    Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
    Electrolux Induction Cooktop Kite C-561 3611 00 Rev B- All the lights are turned on
    We aren't Electrolux, we are FixYa dot com, and you appear to have fixed it.
    Resetting the board would simply involve cutting the power to it. Induction cooktops are a relatively new innovation to the home markets are in general, all Induction cooktops fail due to failing electrical components. I have a 50 year career in catering, and 10 years with induction units. Even the catering quality units with a single hob that cost $1,800 fail in 18 months to 2 years.
    Contact Electrolux direct and ask if they can find the failed component and repair the board.
    https://www.google.com/search?q=%E2%80%8BContact+Electrolux
    1helpful
    Prestige induction cooktop showing error E4
    Good Afternoon friend, I appreciate your inquiry!
    Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
    If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
    1helpful
    Electrolux e21
    Thank you for your post, friend!
    I understand that your Electrolux cooktop is flashing an "E21" error code. Based off the information I was able to look up it sounds like a possible issue within the left board. I would suggest seeking assistance from a technician for proper repair because some of these intricate parts do require precision and patience. Therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. -Matt
    I am having error codes 35 and 75 come up on my induction cooktop
    I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
    1helpful
    ELECTROLUX ERROR CODE E95
    Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
    Error 11 Electrolux induction cooktop
    You will need to consult a professional to have the following repaired:
    1. Test flex cable betweenboards.2. Change right board.3. Change center board (on 36"models only).4. Change left board.
    Jul 23, 2012 • Cooktops
    Please tell me how to unlock and Electrolux induction cooktop.
    If it's in child safety mode, switch on the appliance and touch and - at the same time.
    26helpful
    3answers
    Whirlpool induction ceramic cooktop error E6
    Dec 15, 2009 • Cooktops
    Top Electrolux Cooktops Experts
    Paul Carew
    ADMIN Andrew
    ADMIN Andrew
    Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
