Computers & Internet Logo
v
vinod Posted on Oct 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Device cannot start code 10 - Studio Dell Computers & Internet
Sunil Panem
Level 2:
Scholar:
  • Expert 80 Answers
  • Posted on Oct 15, 2013
Sunil Panem
Expert
Level 2:
Scholar:
Answers
80
Questions
0
Helped
35770
Points
130
Hi
The code 10 normally means driver issues related to the hardware device. It could be either outdated or corrupt drivers for the device.
  • Pls go to device manager and check if there is any exclamation mark by the device.
  • Uninstall the driver from the device manager and restart the computer.
  • If there is a specific driver from the device manager, reinstall the driver and that should fix the problem.
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Device cannot start code 10 means that you are using the wrong drivers for the device or the device has a problem try using system information for windows to find out what drivers it needs if that is the problem but if not the device might need replacing
5helpful
HI
A Code 10 error is generated whenDevice Manager can't start the hardware device, a situation usually caused byoutdated or corrupted driver A device may also receive a Code 10error if a driver generates an error that Device Manager doesn't understand. Inother words, a Code 10 error can sometimes be a very generic message indicatingsome kind of unspecified driver or hardware problem. Uninstalling and then reinstalling the drivers for the device is alikely solution to a Code 10 error. If reinstalling driver is not working than try to rollback the driveror restore the system on previous date.. ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
It gives code 10 error. device can not start
HI
A Code 10 error is generated whenDevice Manager can't start the hardwaredevice, a situation usually caused byoutdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. Inother words, a Code 10 error can sometimes be a verygeneric message indicatingsome kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is alikelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driveror restore the system on previous date..
regards
sandy fixya
2answers
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
2helpful
My audio driver is not working (error 10)
I suggest trying an update, or if you just updated it roll back the driver.
Cd rom wont start (code 10)
Recommended resolution
Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base:
943104 (http://support.microsoft.com/kb/943104/) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
3answers
Code 10: Device Cannot Start
Code 10 refers to the operating system not having drivers to talk to the card. Without the drivers running windows cannot run the device.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
