Question about Garden
Karcher K 2.09 pressure is lower than it was. It still works but at a reduced pressure. What can cure this?
  • 241 Answers
Clean any filters in the water supply line. Clean the tips in CLR to remove any crud buildup. If these action don't fix the problem, your pump seals have worn out. A VERY common problem on pressure washers. Needs professional repair.
Posted on Oct 15, 2013
4 Suggested Answers
  • 32 Answers
SOURCE: Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Posted on Jul 04, 2009
  • 569 Answers
SOURCE: Pressure hose not working on Karcher pressure washer
A common problem with these is a pressure valve inside the unit that controls the power to the pump. If the unit has not been used for some time the valve can stick.
Does the motor run when you press the trigger?
Please respond and I will advise further. (add a comment)
Posted on Apr 06, 2010
brado83
  • 106 Answers
SOURCE: my karcher pressure washer is switching on and off
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this.
Posted on Sep 17, 2009
Karcher k3.00 lack of power
Are you using the same water supply as before when you had good pressure? Some house water lines have pressure reducers to protect your pipes and appliances. This can restrict the water flow and reduce the pressure the machine develops. If the flow surges (good, then weak, then good etc) you are not getting enough water to the pump. Try a larger diameter garden hose (5/8"). If you know where your water line enters the house, try the hose bib closest to it. Often times it is at street pressure instead of (reduced) house pressure.
Aug 03, 2014 | Karcher Garden
What are the health benefits of bananas?
Eating bananas per day helps greatly cure some common health diseases such as reducing stress and promoting weight loss. In addition, bananas have been shown to be effective for improving heart health and providing more energy for the body.
https://wikihomenutrition.com/bananas-health-benefits/
Jan 17, 2013 | Cooking
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
I don't get a constant stream of water from my Karcher 2500 psi pressure washer. instead is shoots in spurtss.
Make sure that while you are running your pressure washer, other machines that pull
large volumes of water like a dishwasher or washing machine are not running. check and make sure
the hose you have tied to the pressure washer is not collapsing or has any kinks in it.
check the filter where your water hose ties in to your pressure washer, make sure it
is clean and does not have any debris or hardwater buildup, clean the tip at the tip of
the wand. if it is reduced in size by hardwater buildup, will not work properly, good luck!
Jul 12, 2011 | Karcher 2500 PSI Pressure Washer
My karcher seems to pulse when on, could this be due to the low water pressure from the hose?
I do not have specific experience of your machine.
However, the high pressure pump will be controlled by a pressure switch on the high pressure outlet to the pipe and jet.
Pulsing (turning off) suggests that the outlet (high pressure) pipe is blocked or partially blocked. Try checking the nozzle and (with the unit turned off) clearing it with a fine piece of wire.
Hope this works
Nic Williamson
Apr 23, 2011 | Karcher K2.26 Electric Power Washer
Hi Bought karcher k5.80 some time ago It didnt work well and I put it away however got it out again its blasts then trickles water on for couple of seconds the off again. What if anything can I do?
I got the same problem as msellar1. Anyone got any ideas to resolve??? medcalf.chris@virgin.net.
Thanks.
Basically, turning the spray nozzle to reduce the pressure works - but this is next to useless for cleaning anything. I fixed the leaky tap in case air was getting into the system but no. It's been like it since day 1, on and off, but now more stop & start than ever! Maybe thats why it was reduced to I think £150 from £275???
May 07, 2010 | Karcher Garden
Karcher 2400 Psi Pressure Washer No gain of pressure
remove the hose from the machine. Check that water is flowing. and there is no corrosion reducing the opening. If that is OK then it is the internal seals and pressure vallve on the pressure unit Cost to have it fixed by Karcher is $200
Thanks for using FIXYA
Sep 26, 2009 | Karcher 2500 PSI Pressure Washer
Jun 29, 2009 | Garden
Garden Logo
269 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
