Question about Dewalt Dcb100 12 Volt Max Fast Charger
The Unit will not charge the battery. - Dewalt Dcb100 12 Volt Max Fast Charger
3300CE charging problems
The battery on my unit is dead. What could be the cause? Possible causes for a dead battery on battery operated units: 1. Battery has lost its ability to hold a charge
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the display is causing a constant draw from the battery.
The battery on my unit is dead What could be the cause
Jan 14, 2014 | Stairmaster Exercise & Fitness
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
I have a olympus fe 20 how do i charge it? can i use the usb?
No, you cannot use the USB to charge it. Your camera uses a LI-42b battery, which looks like this:
You need to open the battery compartment, take the battery out, and put the battery in the charging unit. I'm not posting a picture of a charging unit because they vary, but generally it's just a small box that has a slot to take the battery, and plugs in to a wall outlet. There's usually a LED indicator on it, to tell you when it's charging/charged.
I'm afraid that if you don't have a charging unit, you'll need to get one, you can't charge the battery any other way.
Jan 21, 2011 | Olympus FE-20 Digital Camera
Battery Recharge for Liebert PowerSure PSA
Yes, is the short aswer to your question. The battery should charge as you use the ups. If they don't then its likely the battery/s have failed. Lead acid batteries do not like being left discharged for any length of time. In a motor vehicle the battery gets a bit of shaking around, but in an ups they don't. If not used and left discharged, the plates quickly sulfate up reducing the efficiency to nearly zero. Test and replace any battery that cannot support a test load, such as a bright12v light or a 12v soldering iron connected to it. The length of time required to charge the battery/s depends on their capacity (in ampere/hours) and the charging rate. A 14.4 amp/hr battery charged at say 1 ampere will take 14-1/2hrs to charge.(just as a sample)
Apr 25, 2010 | Liebert (PS1440RT2230) UPS System
Unit won't remain powered-up
You are absolutely correct Jim. Low Battery
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
Dec 25, 2008 | Garmin nuvi 260W GPS Receiver
Battery will not take charge from wall unit
Remove the battery for several minutes, replace the battery and plug the wall socket in, leave it for several hours. The battery is probably too dead to do anything, and recharges very slowly. If this doesn't work, try a replacement battery, before you send the unit in for repairs.
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
Battery charging problem
Where does a person buy a replacement battery
Dec 31, 2007 | Durabrand PDV-709
My charging port seems to not work
My advise to you is if you have Sandisk Sansa m240 it does not come with a chargeable battery so you cannot charge it,replace it and your problem will go away. I replaced my unit with a rechargeable battery and I have no more battery problems. I charge my batter in a charger when needed.
Nov 20, 2007 | SanDisk Sansa m240 MP3 Player
Psp battery won't charge
Its a problem with the unit's charging pins..you will have to get it replaced it shouldn't cost you more than 10$..
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
Charging Problem
Hi, Does the unit run off of the battery? Also, try running the unit without the battery. This tells us several things. Nice unit; I'm working on a similar one now. good luck Harvester3
Aug 18, 2007 | HP nx9110 Notebook
Dewalt Dcb100 12 Volt Max Fast Charger Logo
64 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
Jay Plesset
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
