Question about Lincoln "Lincoln" POPPER Popcorn Maker
The plastic hinge attachments broke on one of the glass dooors, so i need to find replacements. Eden mdl#NP08001
    Champion:
  • 252 Answers
I have never had any luck finding parts from that manufacturer, but here is there contact information.
http://greatnorthernpopcorn.com/t-contact.aspx
Posted on Oct 16, 2013
I need to change the door on my Kenmore microwave oven
1.Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove some mounting screws or retention clips to get the microwave out of the support bracket. Open the door and take out the glass tray.
2.Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the screwdriver or knife all the way around the glass and remove the panel.
3.Ask someone to hold the microwave door as you disconnect it from the hinges. Depending on the design of your microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door. Remove and discard the old door.
4.Have your assistant hold the replacement door up to the hinges. Attach the door to the hinges by reversing the previous step. Snap the plastic inner panel into place around the glass. Move the microwave back to its original location. Insert and tighten the necessary mounting screws if you are working on a built-in microwave. Set the glass tray back inside the microwave and close the door.
Sep 21, 2011 | Microwave Ovens
The rear glass window hinge , one on each side at the top of the glass has broken. The passenger side hinge broke loose and now the glass window is only attached on the left side and at the bottom with the...
Hi. Thanks for your question. For any assistance related to Mazda rear glass window hinge you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Feb 25, 2018 | Mazda Tribute Cars & Trucks
One of the legs of the sunglasses broke off. The hinge is still attached to the leg of the sunglasses.
You may need to replace or rescrew on the other leg, usually done using a small glasses repair kit.
Apr 19, 2011 | Lacoste Clothing Accessories
Interior door glass cracked on my KitchenAid oven
thers the inner most glass then some inner glass packs then the outer determine waht u need take ur model and go to sears.com go to there parts direct or parts research link lookup ur model find the part number and a normal price ........anyways u are gonna have to take the door off and replace it, kinda hard to describr just have to get acesss inside and replace the glass... might need service might be cheaper if u have a local repair shop for u to take the door off and bring it in to them... to get that dooor off most have lil flappers or metal locks open the door fully inspect down by the hinge pulll those flappers back towards glass then move door to brooil position 3/4 way closed and lift striaght up... hope this helps reply or rate me if posible k thanks
Jan 27, 2010 | KitchenAid KGST307 Gas Kitchen Range
96 dodge grand caravan drivers side power window---i have broken the nylon slides that attach to the window itself= do i have to replace the whole window monitor or can i buy the two nylon plastic slides...
It sounds like the Regulator is broken and needs to be replaced. Below is a picture of how the glass attaches to the regulator. Note the gold colored clip in the back that holds the glass to the regulator. IF the plastic piece that broke is the WHITE piece in the picture (yours may be black) then it is part of the regulator.
(the black piece in the picture is part of the glass)
480308c.jpg here is a diagram of your door glass / regulator.
b6fdf08.jpg Hope this helps
Apr 16, 2009 | Dodge Grand Caravan Cars & Trucks
Need plastic handle on Rival Crockpot lid.
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Feb 20, 2009 | Rival 38601 Smart Pot 6-Quart
Frameless shower door sticking to the opposite wall when closing
you can fix this problem by loostening the clamp screw and putting locktite sealer(you can purchase locktite from hd or lowes locktite is not the only product you can call a glass supplier and as for recommendation) Be sure to read the directions on the tube I use it to seal joints on refrigeration threaded parts. Make sure it will adhere to glass and metal also review the clean up solvent when you do this place a wood wedge at the bottom of the glass dooor and the threashold to support he weight until the sealer driese
Steps
1 Place wood wedge/block under door where non hinged side meets wall
2 losten top hinge(inspect bottom hinge to make sure it is snug and the glass dor is all the way into the hinge
3 You may have to remove the top hinge completely to get enough of the locktite on the metal and glass place the locktite on the hinge flat plate and the glass
4 recheck gap where door meets wall( I sometimes use paint stirs(wood) as shims to keep space between door and wall consistent
5 tighten top inge screws( you can put locktite on the screw threas also
6 Clean excess locktite and wait suggested time by instructions on tube
Good Luck!
Dec 31, 2008 | Home
Volvo 2002 s60 fuel door
My guess is that the hinge clips are broken - it's hard to see how it works after the clips are broken off. I purchased and installed a replacement hinge from Myswedishparts.com. I emailed asking for help and they provided direction, but it's pretty easy. Use a small punch to drive the centers out of the plastic attachement pins to get the old hinge off. Replace the hinge, press the center pins in and re-attach the door. There was a drawing on the referenced web site when I replaced mine, but I just looked and didn't see it. I'm sure there are many places to purchase the replacement hinge - that's just where I bought mine.
May 28, 2008 | 2002 Volvo S60
Lincoln "Lincoln" POPPER Popcorn Maker Logo
98 people viewed this question
Top Lincoln Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Lincoln Kitchen Appliances - Other Expert? Answer questions, earn points and help others
