Question about Beko Dishwashers
I have a BEKO DW602 dishwasher. Used first time since it is purchased. Added salt 2kg as required at the bottom. Now after one clear cycle the dirty water has not drained out of this machine. Everything else looks fine. How to get water drained from the bottom of this dishwasher. Please advise...Need urgent help on this.
  • 116 Answers
SOURCE: Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Posted on Mar 11, 2007
  • 1462 Answers
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Posted on Mar 30, 2007
  • 351 Answers
SOURCE: Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Posted on Apr 09, 2008
  • 25 Answers
SOURCE: Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
Posted on Jul 13, 2009
  • 1382 Answers
SOURCE: Water wont drain out of bottom of tub.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Posted on Jul 07, 2010
Pump runs when door is shut and does not first program
May be the selector switch is off of the programming. May have been slightly pulled out on last cycle being used. Try pushing selector switch inward and turn to wash cycle, should feel and hear clicking sound as you turn selector switch
Sep 23, 2014 | Beko DW602 600 mm Silver Built-In...
18 inch dishwasher
I've never heard of dishwasher salt. 2 kg is about 4-1/2 pounds worth.
May 06, 2014 | Dishwashers
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
Hi, I have a BEKO GS5323 Dishwasher that has just
sounds like the sault filter has broken. it is in the base at the bottom its a thin plastic filter type. will need to be changed.
Sep 29, 2013 | Dishwashers
Where do i put the salt in my hotpoint dishwasher ?
If you don't put salt in the appliance then the regeneration crystals will clump together over time and solidify. This will cause a restriction in the softener unit.
If you stopped using it and then started again you may find that the impurities caught by the crystals have simply found their way into the appliance.
You can set the softener to be at minimum setting if you are in a soft water area.
The salt isn't used to soften the water, it's used to clean the crystals in the water softener unit.
Why Do I Need to Use Salt in my Dishwasher?
Salt is needed to ensure that your dishwasher's in-built water softener gives an optimum performance. You will especially need to use dishwasher specific salt if you live in a hard water area. You can purchase one of our Aqua test strips (part number 180876) to determine the hardness of your water from our parts and accessories store or call us on 08448 225 225 .
Manually drain the floor of the machine, put in salt, and check out.
open the salt container at the bottom, and it will be full up with water, and it really will smell bad. clean it and add salt near to 1kg. then run run a prewash cycle and then check out does the salt error is coming up.if yes then more salt needs to be added.
This will help. Thanks please keep updated. please do rate the solution positively.thank you for using fixya
Mar 17, 2010 | Hotpoint 24 in. HDA2000Z Built-in...
Milky residue and a dry salt pot after each wash
It sounds as if there is a blockage in the salt matrix / inlet. This can happen if the wrong type of salt is used.
The simple answer is to use the expensive tablets/pods - that include salt. This will improve the wash and hopefully the blockage will free eventually.
Fill the salt container with water regularly to try and help dissolve it - no salt untill it's clear.
If it doesn't clear within a month - it may need stripping and clearing manually - or continue with the premium tablets untill something else breaks - requiring a service.
Aug 28, 2009 | Zanussi 18 in. DE4744 Free-standing...
Jun 29, 2009 | Beko 24 in. D3421F Free-standing...
Where to add the salt
I have just moved in to a property with a miele dishwasher model no. G1220SCU. I have not been able to locate a manual and it also requires salt to be added
Oct 27, 2008 | Dishwashers
Dishwashers Logo
Top Beko Dishwashers Experts
Shekar Avadhani
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
