Question about Dacor Epicure 30" Double Wall Oven, Stainless Steel - E0230SCH Electric
How do I remove the control panel Dacor PO130BK? I removed the six screws immediately above the door, but the panel is still attached.
  • 296 Answers
Should be two screws under the knobs on front of panel
Posted on Oct 16, 2013
  • Bob Stephens
    Bob Stephens Oct 16, 2013
    Thanks, Ronald. I'm sorry, but my question accidentally got posted in the wrong category. I have a different model - PO130BK, which doesn't have knobs. I'm guessing that I need to pull the oven out of the cabinet, and that there will probably be screws in the top hidden by the cabinet. I just haven't had a chance to check that yet. Fortunately, I have a second oven next to it I can use until I find the time.
3 Suggested Answers
SOURCE: Dacor ECS136 Control panel just beeps but does not work
i am having that problem with my maytag one. the only thing i can do is unplug it and quickly press bake and set the temp and time length. mine says its locked though. i am trying to figure out how to unlock mine.
Posted on Oct 30, 2008
  • 879 Answers
SOURCE: How to remove timer CPO230
Use chisel and hammer.
Posted on Aug 12, 2012
HOW CAN I CLEAN BEHIND CONTROL PANEL TO REMOVE FATTY DEPOSITS ON THE BACK OF THE GLASS
The deposits can be a bit of a challenge as they re on the inner door glass and may be cooked on the glass. You must remove the door off the hinges first and then remove the inner door panel. It will be attached by screws. Once the inner panel is removed, you can remove the glass and clean it with a product called Goo Gone.
Oct 25, 2015 | Ovens
I need to replace the hinge receptacles on a Jenn-air wall oven (WW30430PC). How do I access those parts?
The only way to replace the hinge receptacles is to pull the oven out of the opening. If you need parts you can get them on the link below. Also if you call the link below they will walk you through on how to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45883&diagram_id=28594572#d28594572
May 16, 2011 | Jenn-Air Ovens
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
    Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
    jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
    • Screwdriver
    1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
    2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
    3. Step 3 Place the door on a flat surface such as a table or the floor.
    4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
    5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
    6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
    7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
    Regards
    Iversh
    Jul 24, 2010 | Ovens
    Door remains locked
    Hi
    Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
    To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
    Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Nov 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
    I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
    The switch (reset button) is located about 3 inches behind the door locking mechanism.
    Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
    Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
    Dacor CPS 130 oven will not heat
    This model actually made this way. Sometime you can not see the thermostat because of the bracket in front of the door latch. When you remove grill panel under control panel you gonna see this bracket. It pulls out very easy. Behind the door latch you will see thermostat with red button on the middle. Before resetting this button make sure you disconnect electricity.
    Dec 18, 2008 | Dacor MCS130 Millennia Electric Single...
    Oven won't heat.
    EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
    Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
    Jenn-Air JDS9860AAP Control Panel Problem
    Control Panel
    1. Remove power from unit.
    2. Remove burner switch control knobs.
    3. Open oven door and remove screws securing control
    panel.
    4. Remove screws located on the right and left sides of
    the control panel.
    5. Grasp control panel on the far left and right sides and
    gently pull the control panel out and down.
    NOTE: Gently pull control panel out and down.
    6. Remove infinite switch control knobs, infinite
    switches, indicator lights, rocker switches, and
    electronic control/clock (as necessary) and transfer to
    the new control panel.
    7. Reverse procedure to reinstall control panel.
    Electronic Control
    1. Remove control panel, see “Control Panel”
    procedure, steps 1 through 5.
    2. Remove screws securing electronic control bracket to
    control panel.
    3. Label and disconnect terminal wiring from electronic
    control.
    4. Reverse procedure to reinstall electronic control.try that
    Jan 16, 2008 | Ovens
    My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works
    I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
    Nov 11, 2006 | Dacor ECS127 Epicure Stainless Steel...
    Ovens Logo
    83 people viewed this question
    Top Dacor Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Jaime Hernandez
    Are you a Dacor Oven Expert? Answer questions, earn points and help others
