Question about GE WHSE5240D Top Load Washer
When tub is near full it lt leaks off the back top from the fill . also doesnt spin unless i do a reset then put it to spin .
    Master:
  • 818 Answers
You have an over fill problem-there is a small hose that goes to the level setting control-the hose or the fitting on the tub is clogged cheers Denny
Posted on Oct 16, 2013
4 Suggested Answers
  • 574 Answers
SOURCE: Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Posted on Aug 24, 2009
  • 14 Answers
SOURCE: water runs but doesn't fill tub and wont spin if put on spin cycl
The drain hose must be higher than the tub of the washer so many times I get called to find the hose on the ground to the drain an this will not let the tub fill.
Posted on Jan 28, 2010
richroth
  • 9472 Answers
SOURCE: WBVH5200J2WW GE Leaks from bottom when tub is filling..Alot of water. Pumps out with spin .
Remove the front bottom kick plate to see where it is leaking from.
Posted on Nov 06, 2012
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Leaking from bottom of unit
ok take a putty knife and slide it between the top and front panal,,,, slide it twords the edges until you feel the clip...then push in the clip,, the top will pop open when you have both pushed in,,,,
lift the top up and prop in some manner look down the edges you will see two 5/16 inscrews, take those off and the panal will fall forward
loook under the tub and on the cabinet at that heiht,, if you see a black ring on the inside of your cabinet,,,,, unless your comfortable dooing a shaft seal id stop right there..
if no black marks
put a tub of water in the machnie let it fill
then put it in spin becare full but you should be able to see where the leak is comming from
Nov 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have a twenty year old Maytag washing machine that is leaking water out of the bottom of the machine. I have checked the hoses and it is not coming from there. Any ideas
hello. i can help you. unfortunately, your problem has numerous possible causes.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 02, 2009 | Washing Machines
Fisher & paykel ilw16us leaks water when filling
During fill only
All the time
May 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine is leaking water.
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Nov 18, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
During fill only
All the time
During fill only
All the time
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Zanussi zwf 1437w washing machine
During fill only
All the time
During fill only
All the time
Oct 09, 2008 | Zanussi ZWF1640 Front Load Washer
Kitchenaid Top Loader leaks
During fill only
All the time
During fill only
All the time
Apr 16, 2008 | KitchenAid KAWS700L Top Load Washer
Repair a washing machine
During fill only
All the time
During fill only
All the time
Nov 25, 2007 | Maytag Dependable Clean Top Load Washer,...
GE WHSE5240D Top Load Washer Logo
23 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
