Question about Magnum S9 Base CB Radio
How to turn down power on magnum s9
Hi,i recently bought a magnum s9 and had new rf outputs fitted(as the old ones had blown!)the radio works fine now exept that when i use my variable power to turn down the rf power it only makes 5 watts difference!!(45watts on high/40watts on low)has the variable power been turned up inside?and how to i put it back to standard(i.e 5 watts on low power?any help would be great,thanks dean
    Problem Solver:
  • 5 Answers
Vortash is talking trash mate..
There are two controls towards the rear of the PCB, very close together. They set the upper and lower limit of the variable power. take a look on cbtricks.com for more info.
Posted on Jun 25, 2009
  • freakybwoy Jun 25, 2009
    oh, and the inline thing vorTRASH was talking about is actually called a power reducer, just so you dont go and buy the wrong thing from his suggestions.
    But I will agree that if you are not technically minded, then ask an engineer to do it. would take less than two minutes to fix and 1min 50 seconds would be openening the case.
    Cheers
  • 431 Answers
Sounds like you need a local electronics engineers help , altering the design of an instrument can cause problems and be costly .
Normally an in line filter can be purchased that will affect your output somewhat but it depends on what amount you want to reduce it by remember , if you alter the swf too much then you will overdrive you outputs again and they will probably burn out .
It sounds like at 45watts this system is too powerful for the area you are in I am thinking it is causing interference thats why you want it reduced , again my suggestion is a good TV I filter or change the unit for a less powerful one . One final suggestion is that you have the output 's reduced to a more susatinable rate by the engineer who repaired the set for you ... hope this is of help Regards Vortash
Posted on May 11, 2009
NO variable power on FM,or SSB, but variable works ok on AM
Look for open resistors near by, if the 2SC1969 shorted it has taken out one or two parts, also check for open foils on the printed circuit, beyond this a circuit diagram is needed.
Mar 23, 2012 | Magnum S9 Base CB Radio
Can a magnum s9 work with a standard cb radio
yes. only if it has been modded to work on cb channels. factory boxed radio will be 28-29MHz only...
Feb 15, 2011 | Magnum S9 Base CB Radio
My magnum S9 wanders off freqency an the incoming starts sounding very scratchy, is there a mod ?
magnum s9 they seem to drift a bit on till they warm up my s9 dose the same on till it heats up then it comes ok
Jul 30, 2010 | Magnum S9 Base CB Radio
No power
Magnum s9 rf transistor replacement Hi i hope this link helps you out let me know how you get on with it cheers
Jul 20, 2010 | Magnum S9 Base CB Radio
My Magnum S-9 Import radiow with Top Gun Modulator
The s9 ....you can't cut your power limiter because of the upper and lower side band...thats the onl;y bad things about them radios...you can't get the swing you want because of side band.
Nov 08, 2009 | Car Audio & Video
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Wat power does this radio push
Generally All CB Radios will only push 4 watts. This is only if you have a SWR of 1:1
Jul 11, 2009 | Magnum S9 Base CB Radio
Non capisco come leggere rf se 1 wat o 45
Parlate inglese? Sto utilizzando un traduttore in linea. Sono spiacente se è una traduzione difettosa. Potete inviarli con la posta elettronica a rollincbmods@yahoo.com se volete. La lettura del watt è su un tester di watt. è collegata fra l'antenna e la radio. la rf è potere di radiofrequenza.
Apr 12, 2009 | Magnum S9 Base CB Radio
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Magnum S9 Base CB Radio Logo
569 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
