Question about Quintum Tenor A800 (501-0026-00)
Tenor axt1600 cli login problem - Quintum Tenor A800 (501-0026-00)
How much cost a selmer paris series III model 64 jubilee edition tenor saxophone
I have 51 years experience as a sax player. A new listed price for this saxophone is $7319.00 on sale. Optional finishes would include silver plate-Add $940.00. Gold plate- Add $12,490.00. Better deals can be had from private sales and from various music stores. In my opinion there are better saxophones although I have owned a Paris Selmer tenor sax since 1967.
Aug 26, 2014 | Selmer Paris Paris Super Action 80 Series...
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Jun 04, 2011 | Quintum Tenor DX2060 (501-0122-00)...
I have a tenor dx 6120 connects to an omnipcx office but i cannot make a voip call with it although I 've configured it to make sip call
Unfortunately, there are any number of reasons this could be a problem. The only sure way to tell what's going on is to look at the SIP traffic directly.
If you are up for it, here are the steps you'll have to take:
1. Download and install Wireshark(it's free) from www.wireshark.org
2. Install wireshark on a PC and connect it to the same switch as the Tenor,
3. Configure the switch to use the PC port as a monitor port for the port the tenor is connected to; you need a managed switch for this.
4. Start a capture with Wireshark for the appropriate interface. You'll probably see a shocking amount of traffic on your network all of a sudden. Don't worry, we're going to filter out the stuff that doesn't matter and it will be much more manageable.
5. Click the Telephony tab and select "VOIP calls". Try to make a call or two and see if this provides any useful info.
6. If #5 didn't help, go back to Telephony and select the "SIP" filter. This will provide more basic info on what is going on with the Tenor by showing every SIP packet. If you don't know anything about SIP it can be pretty hard to read though - you may need to post results here and let us take a look.
Jul 15, 2009 | Quintum Tenor DX2048 (501012100) 2x10/100...
I need quintum CLI configuration manual
pls cq
http://www.quintum.com/support/mgmt/index.shtml
u find GUI configuration software & also CLI Configuration manual
Dec 01, 2008 | Quintum Tenor DX2048 (501012100) 2x10/100...
At-8624t
How to Configure the Switch
Some configuration is necessary to enable the switch’s advanced switching
capabilities. This is achieved via the Command Line Interface (CLI). On the
AT-8624T/2M, you can also use the Graphical User Interface (GUI).
Using the CLI to configure a switch
1. Connect a terminal or PC to the Terminal Port (ASYN0).
Using the supplied RS-232 DB9 serial straight-through cable, connect your
terminal or PC to the RS-232 Terminal Port:
• For the AT-8624T/2M and AT-8624PoE, the RS-232 Terminal Port is on
the front panel.
• For the AT-8648T/2SP, the RS-232 Terminal Port is on the back panel.
2. Set the communication parameters.
Set the communication parameters on your terminal or terminal emulation
program to:
• Bit rate: 9600
• Data bits: 8
• Parity: None
• Stop bits: 1
• Flow control: None
3. Log in.
After the switch has booted, the login prompt appears. If the login prompt
does not appear, press [Enter] two or three times.
When the switch boots for the first time it automatically creates an
account with manager privileges. The account has the login name manager
and the password is friend.
At the login prompt, enter the login name and password:
Login: manager
Password: friend
The switch’s command prompt appears. Now use the CLI to configure the
switch.
Using the GUI to configure the AT-8624T/2M switch
This section describes how to establish a connection to the AT-8624T/2M switch
through the GUI so you can configure it before installing it in your LAN.
1. Select a PC to use and identify its subnet.
You can browse to the switch from any PC that is running a supported
operating system with a supported browser installed. JavaScript must be
enabled. If you are using a toolbar or plug-in on your browser to block popups,
disable it while using the GUI. The GUI displays detailed configuration
options and information in pop-up windows.
2. Connect the PC to the switch.
Use an Ethernet cable to connect an Ethernet card on the PC to any one of
the switch ports.
You can browse to the router through any VLAN, as long as you give that
VLAN an IP address. These instructions assume you are using vlan1. All
switch ports belong to vlan1 by default.
3. Access the switch’s command line interface.
Access the CLI from the PC, as described in the previous section, “Using
the CLI to configure a switch”.
Installation & Safety Guide 13
4. Enable IP.
enable ip
5. Assign the vlan1 interface an IP address in the same subnet as the
PC.
add ip interface=vlan1 ip=ipaddress mask=mask
6. Save the configuration and set the switch to use it on bootup.
create config=your-name.cfg
set config=your-name.cfg
7. On the PC’s web browser, bypass the HTTP proxy server, if
necessary.
8. Point your web browser at IP address for vlan1.
9. At the login prompt, enter the user name and password.
User Name: manager <the default>
Password: friend
The System Status page is displayed. Select options from the sidebar menu
to configure and manage the switch.
For context-sensitive online help, click the Help button at the top of the
sidebar menu or on any pop-up page
I hope this helps you out
podum
Sep 01, 2008 | Computers & Internet
D3000 with orion chanal bank
please give me an clear details..
Dec 15, 2007 | Quintum Tenor D3000
Who can help solve my problem
The CM stands for "Configuration Manager", in other words, that is the GUI. The Tenor firmware either starts with a P or an S (e.g. P104-11-00 or S105-01-01)
Sep 17, 2007 | Quintum Tenor ASM200 (501-0132-00)...
I minute remainding voice message
This can only be done via DTMF signaling, not by a wav file.
Sep 17, 2007 | Quintum Tenor DX2048 (501012100) 2x10/100...
Setting up Call Progress Voice Announcement
This is not possible, it is done by DTMF tones only.
Quintum Tenor A800 (501-0026-00) Logo
44 people viewed this question
Top Quintum Computers & Internet Experts
David Payne
David Payne
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
