Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Stand up magic cheef freezer unthawing and hot to touch
  • 241 Answers
A freezer can't "unthaw". It can freeze or thaw. I assume your freezer is not cooling properly and is hot to the touch. First try defrosting the interior. Ice buildup will cause the problems you described. Also check the rear of the freezer and clean the cooling coils so they transfer heat to the outside air.
If neither of these things helps, have a professional check your Freon coolant level. You may have a leak.
Posted on Oct 15, 2013
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Magic chef portable freezer not cooling. compressor running
first of all are you sure its running correctly,if its overly hot to the touch is may sound like its running which it may be,but only on the start/run windings and if left this way it will burn out soon,it needs start/run windings to oppose the pressures inside the compressor to get it up to correct operating speeds,then the start winding cuts out of the circuit,this is where the ptc overload comes into play,as it does this sequence switching to make it operate correctly,just unplug it from the compressor and plug in a new one,also you may think you hear the compressor running,but its only the fans in the unit running,a compressor will run warm but shouldn't be overly hot to the touch,then if this isn't your problem,it could be an evaporator core blocked by ice and you cant get cold thru a solid block of ice so iuf its a self defrost model the defrost thermostat or defrost heater might be inopertive too
Dec 26, 2010 | Magic Chef Chest Freezer MCCF5WBX
Frosting up in the freezer and not cooling in the food compartment kenmore 363.9557852
It sounds like you have a defrost problem.
All the cooling for both sections takes place in the freezer behind the back wall. A fan back there distributes the cold air throughout the freezer and fresh food section. Every 8 - 10 hours a heater comes on for about 20 minutes to eliminate the frost from the evaporator coils back there. If this defrost cycle fails the frost will build up to a point of no air flow so the fresh food side and most of the freezer start to warm up.
The best way to take care of this is to turn it off and unload the freezer, take the shelves out and the screws holding the back panel inside the freezer out. Remove the back panel from the freezer. Use hot water and a hair dryer to unthaw the ice and frost, you will need lots of towels as the melting will bring lots of water on to the floor. Once the frost is gone you will need to install this part WR51X443. The picture below shows it. The kit contains new heaters and thermostat.
Apr 26, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Powers on, but doesn not freeze. There is no noise coming from the freezer.
Try this, unplug the unit for about 5 minutes. This will give the compressor time to cool. Plug it back in and listen to the compressor. See how long it takes for it kick on. When it does is there a click sound, shudder, or is it quiet. Touch the compressor, is it hot. Be careful when you do this as it might be very hot. There could be a chance that the freon has leaked out. Check to make sure there is no dust, lint, debris blocking the filter / vents. Vacuum as needed, it has to breathe. When the compressor kicks on and if it gets hot there is a chance it is bad. The repair for this is expensive and another solution might be to check out craigslist as you can find some great deals. Hope this helps.
JimmyC
Sep 27, 2009 | Magic Chef Chest Freezer MCCF5WBX
Freezer just stopped working
  1. You need to unthaw the freezer, and it should start working.
Sep 11, 2009 | Freezers
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
I just bought a second hand upright 20cubic foot frigidair freezer. Its been on for about 3 hours and it feels really hot to the touch on both sides. Did I just get taken or is this normal? It was running...
Did you lay it down when you moved it?
If so you need to leave it standing up for 12-24 hours before you turn it on.
Or you may have just been ripped of.
Aug 22, 2009 | Freezers
Layer of water on bottom of freezer,causing problem opening bottom drawer, having to use hair dryer to thaw.
If it is a frostless your drain tube is plugged. The water cannot go through the whole to the drip pan so it flows over into the freezer. Unplug the freezer and leave the door open all day to thaw. Or take the back wall out of the freezer and unthaw the drain tube with hot water and a hair dryer.
Nov 17, 2008 | Freezers
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Aug 19, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
67 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
