Question about 5000RS-2W-1 Remote Starter with Full-featured Alarm one 2-way 5 butt
GALAXY 5000RS-2W-M Remote Starter
Would I require a by-pass and/or a wire harness to use this?
For a 2005 Buick LeSabre.
  • 33 Answers
Yes, most gm cars/trucks made after 1988, and just about everything after the early nineties requires a bypass. DEI has a very easy to install and use bypass for these vehicles, the 555L is perfect. If you cannot locate this discontinued unit, I have some available. Respond to this solution with your email, thanks
Posted on May 06, 2009
Remote stop working
You should try replacing the batteries in the remote. If that doesn't fix your problem then you may have a bad remote.
Nov 27, 2013 | 5000RS-2W-1 Remote Starter with...
2002 buick Lesabre (Limited) - When operating the AC I have warm air coming out of the on driver's side vents and cold air on coming out the passanger side vents.
check battery,battery cables,starter,starer solenoid, check if your battery have any power left, by turning lights on, if light is strong then on the starter motor,remove the remote wire, the thin wire connected to the starter from the ign. switch, instead of the remote cable, try to by pass it, with battery voltage, with ign switch on on pasition, if your starter works the starter is good if not change the estater, if starter works then check the remote wire, could be damage, could be the starter switch, fuse , or the starter relay. when working on car always make sure if the engine starts there is rotsting components. Thanks
Oct 15, 2011 | 2002 Buick LeSabre
I have a 2002 Chevy Silverado 1500. I installed
There is a great write-up here: http://newrockies.ca . This was the only system that saved my Park Avenue.
Apr 28, 2010 | 2002 Chevrolet Silverado 1500
When the remote start button is press the car will
Chek the inmobiizer bypass connections if you are not using it chek the tach wire and also perform a learn tachometer.
Mar 18, 2010 | 5000RS-2W-1 Remote Starter with...
Where are galaxy installers in R.I.
Look in the Yellow Pages under 'Car Audio', it will likely be in the 'Automotive' section of the book.
Mar 05, 2010 | 5000RS-2W-1 Remote Starter with...
Where can I get a manual for a galaxy 5000rs
http://www.scytek.net/ ...then go to the 'downloads' section ;-)
Feb 26, 2010 | 5000RS-2W-1 Remote Starter with...
Galaxy GALAXY 5000RS-2W-1 Remote Starter, alarm is triggerd alot, door or hood open everytime.
spray WD-40 on the hood pin switch and the door latch, not unless your car is a ford, it could be the R.A.P system shutting down, diodes may need to be installed
Jan 25, 2010 | 5000RS-2W-1 Remote Starter with...
I have the 5000rs-2W installed on my Audi A6 02. It starts fine but if the system is Armed (locked) the Alarm goes off when using the remote start.. If I use the remote start with the system...
I Sounds like the factory alarm has not been disabled or bypassed properly yet. The car thinks that someone somehow got into the car while it was locked and tried to start it. Had the same issue on my car and had to unlock then lock it again to start it.
Jan 17, 2010 | 5000RS-2W Remote Starter with...
2002 dodge dakota color code for hiter
u can go to the bulldog security website and find the color codes for your vehicle and any possible acc. you may need to complete your install. Good Luck.
Dec 25, 2009 | 5000RS-2W-1 Remote Starter with...
5000RS-2W-1 Remote Starter with Full-featured Alarm one 2-way 5 butt Logo
419 people viewed this question
Top Scytek Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Scytek Vehicle Part and Accessory Expert? Answer questions, earn points and help others
