Question about JVC SIRIUS Satellite Radio Interface for Select CD Decks and A/V Receivers
I am tryin to connect the JVC KS_SRA100 sirius satellite radio interface power cord. The instructions are vague. Do I wire to the radio receiver or to separte wires or boxes
Did you ever figure out how to install it correctly?
Posted on Jun 26, 2009
Backlite display on JVC sirius radio stopped working?
Typical Sirius junk - overheats and display goes out. Buy a new XM Onyx Plus radio instead.
Dec 28, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver
Citroen c15 van i have fitted a radio only when you turn the side lights on it blows the fuse
Does the radio work if the dash lights are off?
I'm wondering if the power and lamp wires are reversed in the 3 wire connector that plugs into the side of the radio.
satellite radio receiver
Aug 24, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver with...
My sirius radio sportster works sometimes and others doesn't
Buy radio shack electronic contact cleaner (in a can) and spray a small amount on the male connector from the antenna wire, and spray a small amount on the male connector in the base of the Sportster that the sportster interfaces with. Place the antenna connector onto the base unit and remove it several times and swirl it while connected. Place the sportster into and remove it from the base several times. This usually will fix the issue. Sat signals are extremely sensitive to the slightest oxidation or dirt or whaterver on that tiny antenna connection point.
Oct 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Satellite receiver not responding
reset the receiver again and try if its responding again
Feb 06, 2009 | JVC SIRIUS Satellite Radio Interface for...
JVC KD-s51
I unhooked the battery from the automobile and reconnected and it solved the problem.
Apr 22, 2008 | JVC Car Dual SIRIUS Satellite Radio/CD...
How do i set a jvc kds-32 radio clock
You'll find your answer here:
http://books.jvcservice.com/booklist.asp?Model=kds-32
Just download the pdf instruction manual.
Jan 08, 2008 | JVC Car Dual SIRIUS Satellite Radio/CD...
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
"buzz" when Sirius receiver is plugged into AUX input of new Camry
Did you have the unit installed at a shop that would have hardwired the power source? It sounds like either your power wire to the sirius unit is connected to a noisy power source (which is why you are picking up the alternator whine), or you have a poor ground connection to the unit. If it was installed at a shop, take it back and have them move the power source to the same wires that the radio gets power from. If you are using your cigarette lighter for power, unfortunately it sounds like your outlet doesn't give you the best source for powering an audio component. You might try stopping by a car audio shop and ask how much it would cost to hardwire the sirius' power to the back of your radio.
Nov 07, 2006 | Sirius Satellite Radio Sirius Starbase...
JVC SIRIUS Satellite Radio Interface for Select  CD Decks and A/V Receivers Logo
150 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
