Question about Breadman TR500 Bread Maker
I have a TR-500 model. How do I know if it is a 1 lb. or l1/2 pound model
  • 120 Answers
Go to google.com search the TR-500 specification manual and read it.
Posted on Oct 15, 2013
3 Suggested Answers
daryl441918
  • 1280 Answers
SOURCE: how many pounds does the trillium tr-500 bread
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
Posted on Nov 27, 2010
daryl441918
  • 1280 Answers
SOURCE: lost manual need to know
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
Posted on Dec 18, 2010
How many cups are in a pound of powdered sugar
1 lb. sifted powdered sugar = 4-3/4 cups
1 lb. unsifted powdered sugar = about 4-1/4 cups
Jan 31, 2015 | Ice Cream Makers
1 lb 60z what is mean.pls answer me
What's the question?
Since one pound is sixteen ounces, 1 lb 60 oz is 4 lb 12 oz.
Aug 17, 2014 | Cars & Trucks
How many 500cc scoops are in 15 pounds
It depends on the density of the powder. Cubic centimeter (cc) is a measure of volume while pound (lb) is a measure of weight.
15 pounds of water occupies about 6800 cc, while 15 pounds of gold occupies about 500 cc.
Mar 27, 2014 | Office Equipment & Supplies
I can't find a model # on my kitchen pro bread maker, all I can find is the date of manafactor 1997. I just need to know the capacity. 1 or 1 1/2 lb.
Feb 01, 2011 | Regal Ware K6725 Kitchen Pro Bread Maker
Lost manual need to know if the trilium TR 500 breadman is a 1 lb or 1 1/2 lb machine and directions. lost the manual
FROM ANOTHER SITE:
Dec 17, 2010 | Breadman TR500 Bread Maker
How many pounds does the trillium tr-500 bread baker make? 1 or 1 1/2 lbs?
Nov 27, 2010 | Breadman TR500 Bread Maker
I'd like to know the loaf size/weight for a Welbilt ABM-100-3 bread machine - 1 lb or 1.5 lb
Nov 25, 2010 | Kenmore KTR2300 Bread Maker
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Jeep grand cherokee revs for to high before changing gear
Message:
My 2002 Dakota has been somewhat confused about shifting as well. It showed a code P1762. I dropped the pan to install a new fluid filter and fluid-(use only ATF+3 or ATF+4). Since the pan was off I decided to adjust the bands. The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
The front band adjusting screw is on the driver's side above the shift linkage. The rear band is inside the fluid pan near the filter.
1. Loosen band adjusting screw locknut. Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw
threads if necessary. The front band adjuster is on the outside of the transmission and the locknut requires a 3/4" wrench.
2. Using Inch Pound Torque Wrench C-3380-A, a 3-in. extension and appropriate Torx� socket (T-40), tighten adjusting screw to 72 in-lb. CAUTION: If Adapter C-3705 (from SPX Miller) is needed to reach the adjusting screw, tighten the screw to only 47-50 in. lbs. torque.
3. Back off adjusting screw the number of turns listed below for your transmission.
4. Hold adjusting screw in place and tighten lock-nut to:
41 N�m (30 ft. lbs.) for the front band
34 N�m (25 ft. lbs.) for the rear band
The adjustment screw inside the case is a square head bolt. You will need a 1/4 square head socket to fit your torque wrench.
Band adjustments for each model year:
1994
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
o 32/42RH - Tighten to 72 in-LB, back off 4 turns
o 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
o 42RH - tighten to 72 in-lb, back off 2-1/4 turns
o 46RH - tighten to 72 in-lb, back off 2-7/8 turns
o 47RH - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE/RH - tighten to 72 in-lb, back off 4 turns
o 46RE/RH - tighten to 72 in-lb, back off 2 turns
o 47RE/RH - tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
o 42RE - tighten to 72 in-lb, back off 3-5/8 turns
o 46RE - tighten to 72 in-lb, back off 2-7/8 turns
o 47RE - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE - tighten to 72 in-lb, back off 4 turns
o 46RE - tighten to 72 in-lb, back off 2 turns
o 47RE - tighten to 72 in-lb, back off 3 turns
1999
* Front Band
o 42RE - tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
o 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
o 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
+ The 47RH rear band requires a 1/4" hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
o 42RE - Tighten band adj. screw to 72 in-lb, back off 3 turns
o 44RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
o 46RE - Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
o 47RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory
specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns.
Depending on the circumstances I have backed off the band up to 2 1/2 turns.
* Rear Band
o 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut - 30 ft-lb
* Rear band adjustment locknut - 25 ft-lb
* Transmission pan bolts - 13 ft-lb
I just replaced the solenoid with the recommended transducer and all is fine now. The transducer cost me about $50 at a nearby dealership.
Hope this helps. -zman. rroszman@yahoo.com
Dec 09, 2008 | 2001 Jeep Grand Cherokee
Regal Breadmaker model K6725
Hello grmccauley,
According to the cover of the manual, it makes a 1-1/2 to 2 pound loaf.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Nov 02, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Breadman TR500 Bread Maker Logo
96 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
