Question about Maytag Neptune MAH9700 Front Load Washer
Did maytag go out of business - Maytag Neptune MAH9700 Front Load Washer
Is Maytag a good washing machine brand?
Hi
According to Consumer Reports, Maytag washers are among the best in the business.
Check the link below.
-Steve
Best Washing Machine Brands Top Washing Machine Brands Consumer Reports
Apr 22, 2015 | Maytag Washing Machines
Noisy front load maytag washer
Center bearing going bad,Maytags have a history of this and the whole tub will have to be replaced cause the bearing is made no to come out and.it's best to get a extended warranty on all Maytags,the repairman is so busy now days.
Feb 16, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag - MDB6769AWB touch panel blinking
Time to call the business that sold the machine for warranty service or immediate replacement! The threat of losing a sale will usually get them off the dime in short order. Hope this gets the problem(s) resolved in a hurry. Good luck!
Jul 24, 2010 | Maytag MDB6769AW Builtin Dishwasher
Is it true that the Maytag company is out of business, my husband wants to get rid of our washer because he said that the company is out of business and no parts can be found
Maytag is now owned by Whirlpool, who also owns Kitchen Aid, Jenn Air, and a couple others. You should be able to find parts for most models, but if the unit is old, they may no longer be available.
Try repairclinic.com or apwagner.com
Jul 27, 2009 | Maytag Bravos MTW6600T Top Load Washer
Top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Jul 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Free advice on what recalls maytag is fixing free on front loading neptunes w/built in water heater
Fee advice???are youlookingperhaps for possible recalls on the maytage front loader?? a call to the manufacture with the model and seriasl number will enable you to acess all the current recalls
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Admiral AW22
Maytag UK
Foxbro Business park
Redhill
Surrey UK
44(0)1737231000
Fax 44(0)1737778822
They will fax you drawings, tell them you need to identify some part.
Contact me if you need help on this machine , I am familiar with the model I have looked afety two machines for 7 years now and know them quite well.
markthespark@live.co.uk
Oct 11, 2008 | Maytag Admiral AAV7000A
Maytag Atlantis
Mine is doing the same thing. In 2004 (might be 2003 or 2005), Maytag redesigned the insides. They were getting complaints from the Maytag dealers and repairmen about having to replace the bearings on so many of the machines. Maytag redesigned the entire part and paid all customers to have it replaced. My machine had the bearing replace and the entire part replaced. It fixed it for a little while, but started doing it again not long after. I happened to be the bookkeeper for the Maytag dealer I bought my washer from. He was so frustrated with Maytag (along with many others who attended the same Maytag repair schools). Maytag never did recall the product. Only offered to replace it for free and waited out the warranty on these bad washers. They have now gone back to the original "dependable" design, but it does not help us who are still having issues and out of warranty. I never have understood why they weren't forced to recall the product. Or how they could choose to voluntarily replace the bearings until the warranty was out but never have to stand by the product afterwards. This very washer was the demise of the business I worked for. Not only was this struggling dealer having to spend all of his time repairing these washers but customers were no longer willing to by the "dependable" Maytag anymore. In fact, my boss said "So much for the lonely Maytag repairman" like the commercials always say. He visited with many in the same line of business in the smaller towns and they were all struggling also. Many customers held them responsible and began shopping at the big box stores for other brands.
I can't remember what the part was exactly. It had to do with a part that had two bearings one on top and bottom....seems like it was in the transmission.
Oct 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag MZD2766GES Side by Side Refrigerator
Not actual stainless steel or the magnets wouldn't stick then all those frige magnet companies would go out of business. Maytag should make a cleaner/protector spray or something that will clean that up. Even the DIY stores like Home Depot or Lowes, etc. should have that type of cleaner. Naval Jelly can work but test in on a spot that won't show in case it stains the finish more than helps remove the rust. And yes, that would be cosmetic issue not a warranty item usually BUT read the extended warranty yourself to see if there is a loophole!
Oct 30, 2006 | Maytag MZD2766GES Side by Side...
Maytag Neptune MAH9700 Front Load Washer Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
