Question about Samsung Dryers
DV328AEW/XAA dries one load and quits until cool
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Typical 'motor over heat' or weak thermostat problem. Try starting the dryer just after it over heats. What happens..A humming sound?...motor is overheating and seized up....if quiet, could be motor as well. Check that your dryer vents are open and clear.
Posted on Oct 17, 2013
4 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: DV328aew/xaa Samsung frontload dryer. dryer spins
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground. You can check out the exploded parts diagram for your dryer on this link---
Samsung DV328aew/xaa Dryer Exploded parts diagram
Hope this helps... Please post back if you need more assistance.
Daniel
Posted on Nov 20, 2010
livewire874
  • 618 Answers
SOURCE: dv328aew/xaa dryer not heating
If the fuses at the panel are ok then could be the heater, thermostats, sensor or control.
Posted on Dec 07, 2010
  • 222 Answers
SOURCE: The dryer won't heat up.
check the motor if running? if running check the back ofyour unit when you see the exhaust pipe and clean it,and the filter inside thedryer clean it,if this one is ok.the sensor of your dryer or the heater is totally wort out,check the backof unit and look when place the heater?some model is easy to remove the heater at the back,just using screw driver,and easyto check,if the heater is continious coil it is ok,if split or broken replacethe new one,carefully to remove and carefully to return,make sure is the unit inunplug before anything to do.
Posted on Jan 04, 2011
Dv328aew/xaa runs about 10 seconds then stops with error code hE
Heater Error. Samsung believes only its customer support team is capable of solving the problem. If you go to www.repairclinic.com and enter Dv328aew/xaa, you may find a more practical answer.
Aug 29, 2016 | Samsung WF419AA Front Load Washer / Dryer
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
Samsung dryer dv328aew/xaa won't turn off
It seems to me that you have a defective relay in the main control board.
Oct 30, 2014 | Samsung DV328AEW Electric Dryers
The dryer won't heat up. Model # DV328AEW/XAA.
Jan 04, 2011 | Samsung Dryers
Dv328aew/xaa dryer not heating
Dec 07, 2010 | Samsung DV328AE Electric Dryer
Gas dryer turns off when load is nit dry
You may want to clean out the dryer's insides as well as your venting that leads outside. This may be the reason your dryer isn't fully drying. It basically isn't running efficiently enough due to age or lint build up or both. As far as the running after it's cooled down it may be a "wrinkle guard" where it tumbles the clothes until they have cooled down.
Mar 14, 2010 | Dryers
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
Nov 18, 2009 | LG DLE7177 Dryer
Dryers Logo
148 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
