Question about Miele Freezers
Fan vibration - Miele Freezers
  • 31 Answers
Fan vibration sometimes caused by dirt/dust on the fan blades.
Posted on Nov 07, 2013
What is causing Scotsman icemaker to moan
perhaps it's unhappy? I can't say i blame it, if I had to sit there all day in the freezing cold making ice I would moan too.
here's a list of possible problems
If it makes excessive noise:-
Problem and Likely Causes/ Probable Solutions
Fan blade vibrates Blade is bent Replace fan blade
Fan motor mount is broken Replace motor mount
Compressor vibrates Mounting loose Check mounting
Water pump vibrates Pump bearings worn Replace pump
Panels vibrate Mounting screws loose Tighten screws
and ice can groan as it expands, but that only applies to large icebergs
May 14, 2014 | Scotsman Freezers
Compressor runs but wont cool
Make sure the compressor is running it should be vibrating and get warm after a few minutes. If it is indeed running the smaller tube to the compressor should be getting warm if not it could very well be the compressor has stopped pumping. If the fans are not running they could be controlled from the control board and will come on when the sensors on the evaporator get to a certain temperature. I does sound like the compressor is the problem.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
Miele freezer The fan on my standalone Miele
Hello David Riome,
Why are you discovering a FACTORY ASSEMBLY
does not fit ...??
(just be sure... KITCHENAID was one of my worst).
and keep in mind...
ALUMINUM only bends a very few times before
it breaks (soft, brittle & very difficult to repair).
((protect it)).
The FAN must be free of all obstructions to function.
If it is out of balance, worn or broken in ANY WAY...
REPLACE IT...
Make sure all wires and lines are ABSOLUTELY
NOT in contact with the fan bracket...
(secured out of the way).
Most of these newer units have aluminum evaporators
and a FAN BRACKET will easily wear a HOLE in
your REFRIGERANT LINES.
Like a saw... It may take a couple of years but
sure as winter follows autumn... $$$$$ damage
from conflicted refrigerant lines.
Move the wires and lines away from the FAN.
Carnac the Magnificent
May 13, 2017 | Miele Freezers
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
MY HOTPOINT FFA52 FRIDGE FREEZER HAS MADE A LOUD BUZZING NOISE A COUPLE OF TIMES BUT IT APPEARS TO BE WORKING OK. AT FIRST I THOUGHT THE BUZZING WAS COMING FROM THE TOP NEAR THE THERMOSTAT UNIT BUT I,M NOT...
If you can pull the unit out from the wall, find the motor compartment. There, you'll find a black can with the motor and compressor inside it. This usually creates vibration when running. Check the compressor's mounts, to see if they need tightening or have rubber grommets that have rotted away. The sound could also be coming from a fan somewhere in the machine. There might be a fan in the motor compartment. Find the vents inside the unit that blow cold air. Check the guards to see if a foreign object could have made its way into the vents and jammed a fan. Make sure you unplug the fridge before you stick any hands or tools someplace they wouldn't normally go. You may want to let the unit run while peeking in with a flashlight to locate the source of the vibration, but beware of moving parts and a shock hazard.
Apr 03, 2010 | Freezers
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Kelvinator Single Door Hardening Cabinet Flash Freezer fan
If the fan motor shaft is smooth with 1 flat spot the hub on the blade probably has a hex set screw that can be tightned with an allen wrench. If the fan motor shaft is threaded there should be a nut holding the blade on. Also yur motor bearings could be going bad causing vibration which damages the fan blade.
Sep 22, 2009 | Electrolux Freezer Kelvinator Single Door...
Freezer don't get cold-fan turns on ,timer is ticking,black thing under is vibrating,coils are clean
1st check the compressor working or not working .OK compressor is working system gas leak ,not working check the capacitor and timer contector
Jun 20, 2009 | Frigidaire Freezer FFU11FC2CW 11.2 Cu.Ft....
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Freezers Logo
55 people viewed this question
Top Miele Freezers Experts
John Tripp
John Tripp
Jay Finke
Jay Finke
ray gallant
Are you a Miele Freezer Expert? Answer questions, earn points and help others
