Question about Canon Pixma MX452
I cannot send a fax!!!! I'm so frustrated, I have done everything the instructions have said to do, and it's not working. Before I take this back,what else should I try.
  • Canon Master
  • 7,993 Answers
Have you tried to fax directly from the machine? For this you need to connect the phone line to your All-in-One Pixma. Can you copy directly on the machine. If you can do that the machine is not at fault. You do not even need ink for faxing.
The next step is to hook the machine to the computer through USB and install the software (drivers and application). Try to print from the computer. If it works then you may have a configuration problem with you connection (Ethernet or Wireless).
I will finish with the obvious: Reread the installation procedure patiently. Reinstall the drivers and the application software. Read the router software and use the router management to configure your connection.
Posted on Oct 15, 2013
Lexmark 5250 won't fax. I have installed everything several times but says something about OCR not working. It will scan & print instead of sending document to Fax. I can open Fax window, but...
Use the Lexmark All-In-One Center application to send faxes from your computer (make sure your computer is connected to a fax modem). From the Creative Tasks section of the All-In-One Main page, click Fax using PC modem. Follow the instructions on the computer screen.
Jul 25, 2011 | Lexmark X5250 All-In-One InkJet Printer
Can send but not receive faxes. dell 1815 dn. I can do everything else, just not receive faxes, went through help lists and have follow everything to no avail...i need it to work:(
Did you check the "answer call after x rings" option?
It sometimes defaults to 7 rings, at which time the sending fax machine has given up already.
You find the settings here: "Fax -> Fax Defaults -> Rings to answer"
If this solved your problem - great!...If not, just come back and leave a comment - I'm happy to help.
May 22, 2010 | Dell 1815dn All-In-One Laser Printer
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
HP C7280 All in one wont send faxes
First clear the fax memory and then go to go fax menu and then settings
then DRPD set it 9600, and then try to send a fax ...
Good luck...
Feb 02, 2009 | Office Equipment & Supplies
Cannot receive faxes
1-are you sure it is in the correct jack? there are two in the back of the printer
2-when you did the install it should have done a fax line check
Sep 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Receiving error
Ok...so I fixed my own problem. I had printed out a system data sheet on my fax machine and found out that the "error" was in under sending confirn, so I went into my menu to the sending confirm section and turned it off. Then my boss tried sending the fax and it came through like nothing was ever wrong...I think the other day when my Iguana got in my office, he must have done something, as I found him perched on my fax machine....hmmmm. Thanks for the follow-up email.
Apr 09, 2008 | HP 1040 Plain Paper Inkjet Fax
Problems receiving faxes in memory
Just had the same trouble. I loaded paper. Tried more paper, tried less paper. No luck. Finally in deparation and trying "everything" I could think of, I pressed "stop/reset" before pressing "start/copy" and now it's working. Very frustrating!
Aug 30, 2007 | Canon FAXPHONE L80 Laser
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MX452 Logo
105 people viewed this question
old marine
old marine
