Question about RCA WHP141 Consumer Headphones
HOW CAN I FIX THE BUZZING SOUND IN MY HEADPHONES? ITS TO THE POINT OF NOT WANTING THEM ANYMORE. THANKS......
  • 422 Answers
Its running on 900mhz, a frequency shared by many things, eg amature radio, cordless phones. try move it around and see which gives the least interference
Posted on Oct 16, 2013
What is causing humming sound in headphones?
Well, there are a couple things in the troubleshooting process you may want to check first. If Possible,
1. Have you tried a different pair of headphones thru the same jack?, Is it buzzing as well? Then its not the headphones. If the buzzing stops with a different pair, then we proceed to to headphones in question.
so , headphones are buzzing. Both sides? if yes , or even 1-side, then yes, it is a ground issue. can you expose the wiring at the input jack?
Basically, you want to put an ohm meter on each wire and independently check each wire for continuity. check for any breaks in the line, and or check to see if a wire is crossing over to ground via a break. so check each line to itself, then each line to each other.
if you fo not understand on the process of using an ohm meter? you can go to this You Tube link and it will give you a general understanding.
hopefully this gives you a little insight? If not?, ask the question again, and also include the make & model of the headphone set. that always helps;m Thanks,
Good luck.!!
Mar 22, 2016 | Music
Color Tv
Buzzing nois of this kind can come from a short or from disturbance.
Aug 11, 2008 | Sylvania 6413TC 13" TV
Hi: I have a aiwa nsx 800 mkII I hear left channel normal but the right channel sound very low ?qhere can I fix that?
Check first it is on all functions. If it is then it will be a power amp fault. As the unit has two channels both of which are identical to each other it's possible to check and compare each channel. So in your case the left hand channel parts are your guide to what is right. Compare first visually the two channels. If something looks burnt or damaged or wrong in the right, but it isn't in the left then you will have found the cause.
If everything looks OK, then carry out voltage tests, if you have a meter. Or a sound test. This involves touching with an insulated screwdriver the two channels while the unit is on. Never touch any part that there is only one of. Unless it's an IC and has two channels going in it. You will hear a buzz if it is working or produces sound. Again a good buzz in the left should happen in the same place as the right. When it's load at one point of a part but weak on the other, when it should be a loud buzz then you have found the faulty part.
Please however check first that it's not the headphone socket that is causing the problem. Sometimes the sound will be OK on headphones but not on the speakers. The socket the headphones fit into can cause this.
Oct 23, 2015 | Aiwa Audio Players & Recorders
How to fix buzzing in transcriber
Possibly the head has contacted dust particles, causing the buzz sound, try using a swab to clean the head.
Feb 02, 2015 | Panasonic Rr-830 Standard Cassette...
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Does it buzz through cans? (headphones). Try listening on headphones (turn off any amps and speakers) on cue to each channel you use and to the master output. is it stil there? if so it's an all round earthing fault. If it's all good through the cans (sorry...I mean headphones), try it with the amp/s on again. If the buzz is back it souds like the screen on the main audio output connecters has come off inside.
It's a quick fix, but if you have never used a solder iron, take to someone who has.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
I have two sets. One has a buzz. The other has a
Try phoning Sound Idea Audio and Video Store at (817)346-4500 for advice.
Jul 07, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
AKG K240S headphones not working well.
A buzz in one ear and no sound in the other 'sounds' like an open connection inside the headphones. The K240-series uses three wires from the pin to the headphones. Try this link to get wiring schematics and disassembly details: http://www.akg.com/site/powerslave,id,7,nodeid,7,_language,EN,cat,11.html
DHE 2008
Jan 07, 2008 | AKG K 240 Studio Professional Headphones
Headphone jack
I had to take mine apart and re-solder the headphone jack. It was amazingly easy, but if you don't do electronics repairs, I would suggest getting help. Everything is very tiny! This type of head phone jack is modular and soldered directly to the tiny internal circuit board. It is poorly anchored by the outside of the case where you plug into it, so most of the stress of pluggin and unplugging the headphones is put directly on the three tiny little solder joints. This causes one (or more) of them to break eventually. Mine lasted only about two months. And, I was carefull very gentle with it! This will cause one side or the other, or both speakers to lose their signal so that only one side works or worse, niether side works anymore. Consequently, I don't unplug mine anymore. If it breaks again, I may try to fix it. It only takes a few minutes. But, I'm hoping I don't ever get to that point.
Sep 01, 2007 | SanDisk Sansa c240 MP3 Player
RCA WHP141 Consumer Headphones Logo
176 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
