Question about GE GTDP300EMWS Dryer
When pushing the start button the dryer makes a buzz sound but nothing happens. If the belt was broken I should hear the motor running. The dryer is 18 months old and gets normal use for a small family. I wonder if the motor went bad or maybe a relay might be the problem.
  • 106 Answers
Most likely the motor. If you have a second set of hands, you can try and hand start it. Open the door, hold in the door switch (or tape it, if you don't have anyone to help), press the start button, and then grab one of the drum fins, and spin the drum counterclockwise and see if it takes off.
Posted on Oct 15, 2013
  • 641 Answers
SOURCE: Model DWLR473ET0WW Makes buzzing noise when I attempt to start it but will not start
Following your description it sound like a capacitor issue. Good luck !
Posted on Aug 18, 2007
kevin000
  • 1847 Answers
SOURCE: the start button on the
i feel it is loose connection issue,
Posted on Jun 08, 2008
  • 1122 Answers
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Posted on Mar 21, 2009
heatman101
  • 43501 Answers
SOURCE: dryer does not start
Sounds like your motor has gone bad...
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 17, 2010
Testimonial: "Thanks heatman. I appreciate the timely response and links. Will follow your advice to try to isolate the problem."
heatman101
  • 43501 Answers
SOURCE: GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
heatman101
Posted on May 29, 2010
My LG Tromm dryer makes 3 clicking sounds when I push the start button. Everything lights up as if it is going to work, but when "start" is pushed, I just hear the 3 clicks and then nothing happens
If the drum doesn't turn, check the centrifugal switch on the motor shaft. Check if the belt hasn't broken or if it's off the motor shaft.
Jul 16, 2014 | Dryers
Dryer quit in the middle of a load, pushed start button, hear an electrical buzz by the selector knob, nothing happens. tried another selection, nothing happened. checked lint hose & it was clear. is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 24, 2011 | Frigidaire FDE336RE Dryer
When you push the button to start the dryer, all it does is buzz and nothing happens
next time send the model number and brand name,all dryers are not the same!it sounds like a bad motor.open the door,push the door switch in with one hand and with the other spin the drum,while you're spinning the drum have someone push the start button,if the motor starts you'll know the motor is bad but it might run for a while before it does this again or it will do it every time but either way the motor should be changed,also on some dryers if the belt broke it will buzz like when the dryer is down but if yours is more like a humming sound like power is going to the motor but it won't run then it's the motor.
Apr 24, 2011 | Dryers
My dryer will not start. when i press the start button i hear a faint buzzing sound and nothing happens, the inside of my dryer warms up a little. other then the buzzing sound i hear no noise.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 31, 2011 | Dryers
When I turn the start button nothing happens except a buzzing sound...no tumbling happens even if the dryer is empty.
There are two causes for this...bad motor or broken belt... If you are getting a buzzing sound then I would vote for the motor...
Check out a tip that I wrtoe about this...
heatman101
Mar 31, 2010 | GE DVLR223 Dryers
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Dryer won't start when pushing the button it clicks
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
Jan 14, 2009 | Kenmore 62602 Electric Dryer
Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Mar 24, 2008 | Estate TEDX640JQ Electric Dryer
GE GTDP300EMWS Dryer Logo
139 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
