Question about Kenmore Side by Side Refrigerator
Need wiring diagram for kenmore 106.53532300, connector missing on my refrig after a move. Not sure on correct hookup if I replace the wiring harness.
2 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: need wiring diagram for kenmore elite refrig-
http://appliancedigest.com/index.php?/files/file/498-16025629-maytag-amana-bottom-mount-refrigerator-service-manual/
Posted on Nov 03, 2010
Diagram for heater blower wiring ford contour blower not working some wires look melted
I need model year to be sure I post the correct diagram? Probably a two wire connector at the blower motor, voltage and ground. Check voltage and ground, if your missing one or the other, track that circuit. If you have both good voltage and ground with no blower action, suspect the blower motor. I need more info.
Dec 17, 2016 | Ford Cars & Trucks
I need a wiring schematic for a Kenmore model 79040522400 wall oven . Control panel the five wire that hookup on side for broil, bake, etc
diagrams are inside the control panel, usually in an envelope to the left or right side of center. If not there, look on the top or rear panels as they may be adhered to either of those. Worst case is someone took them from the unit during service in the past and never replaced them. Last option is to look online at sears parts direct. They show the diagram, but it is not clear.
Jan 26, 2015 | Kenmore Ovens
I removed the console on my Kenmore washer 11047781700 I dont remember where the 2 connectors attach and wireing info is missing can you help
Check to see if your pressure switch needs two wires. If both wires have special ends on them, then they might belong on the control board and they can only fit in two certain spots
Jan 26, 2015 | Kenmore Washing Machines
Squirel ate through wire harness connector on coil pack. I have found new connector with generic black 4 wire harness, but need to know the correct order to connect to old (multi-colored) wires leading...
Check the right wiring diagram connections... 2002 Mercury Cougar 2.0 liter DOHC L4 VIN "3"
Also, I find few diagrams about Igniotn System...
Fig. Engine Ignition, Page 01 (2002, System overview)
Fig. Engine Ignition, Page 02 (2002, Duratec-VE)
Fig. Engine Ignition, Page 03 (2002, ZETEC-VCT)
Hope helps.
Feb 22, 2011 | 2002 Mercury Cougar
How many ways can the wires be hooked up for the fuel pump? i am not sure if i have them on correctly.does not seem to be getting fuel to the fuel rail.my wire harness has three wires to hookup on top of...
One of the wires is for the gauge sender. You can check for voltage at the ends of the wires using a test light. There should be voltage there briefly (one second or so) when you first turn on the ignition. You need to get the polarity of the pump wires correct, so you might have to try both ways and see which way it pumps fuel. Was there not an electrical connector on the tank? You could also find a wiring diagram and determine which wire is which by color, and then check the connector pin digram to determine which color wire goes to which pin.
Aug 24, 2010 | 1988 Ford Bronco
I have a HP-Pressario 10 Desktop which had the cables from the 250 watt power supply unhooked. I need a diagram to rehook the cables correctly. This is a 20 pin hookup.
well the PSU cables for the mobo should only be able to be hooked to one place on the board. i'm not sure if this is a 20 pin and a 4 pin or just a 20 pin, but the 20 pin connector should only fit one place and snap in. you don't need a diagram, if you're wondering about all the rest of the cables it doesn't matter where you plug what 4 pin connector to. as long as they're connected..
Oct 02, 2009 | Compaq Computers & Internet
Wiring
You are missing over $150 in parts. You can buy a working unit out of the newspaper for that or less.
All of the wires on those models have letters and numbers on them near the connectors at each end.
Go to the Sears Parts Direct website with your Model Number and you may be able to print out a wiring diagram, because that is what you will need.
Jul 13, 2009 | Kenmore Elite HE4 Electric Dryer
WIRING DIAGRAM
The manufacturer normally places a wiring diagram inside the operator console. Remove the back panel and there should be a diagram taped inside. Some of these diagrams will show two circuits. One is for a gas dryer, and one is for an electric dryer. Make sure you reference the correct one. I hope this helps you. If you need further assistance please let me know.
Aug 13, 2008 | Kenmore 63942 Dryer
PTC relay on compressor
Try to find the "secret" wiring diagram.  Almost all refrigerators have a hidden paper wiring diagram.  It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan.  While you're in there, it's a good practice to clean the coils.
Oct 19, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Side by Side Refrigerator Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
