Question about Dryers
Kenmore dryer model 86880100: Start button would just buzz when pressed, sometimes actually start the machine, then the machine would run for a few minutes and turn itself off with a burning smell. Now stop button does not even buzz and does not start machine at all (even when empty). Would like to buy parts and fix myself, but need advice on what to buy. Thanks!
  • Roger Browner Oct 25, 2013
    Thanks. I waited too long to fix it and burned out the motor altogether. Turned out there were screws from my pockets stuck in the impeller. Learned a big lesson about emptying my pockets before washing clothes!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Sounds like a over heated motor which starts when the motor is cool but not after it runs and stop. Burning smell comes from the heated windings on the motor coils.
Make sure that the pully is not binding...which i doubt.
Posted on Oct 17, 2013
SOURCE: Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Posted on Feb 04, 2009
erickg
  • 116 Answers
SOURCE: Dryer won't start. Pressing "Start" button just emits 4 beeps.
does the drum turn? if it doesnt you can assist it and see it that is problem, have to remove top and push it. that would be capacitor on motor or jumper the door closed switch and try to spin.
Posted on Apr 21, 2009
pollyluvpat
  • 103 Answers
SOURCE: samsung front load dryer had a burning smell-it
ck recalls on this issue.
there may be one.
under warranty??
do not buy samsung they are notorious for having problems.
sounds like the heating element and relay may have went out.
however if it does not start up at all it could be the motor itself.
Posted on May 14, 2009
Controlfrk
  • 304 Answers
SOURCE: I have a Kenmore 70 Series electric dryer #66702
This is usually caused by a motor getting too hot. The motor has a shutoff to protect it against burnout. It will reset when it gets cool. As the motor overheats more and more these shutoffs become more frequent and longer
Motors get hot for several reasons:
1. Motor going bad
2. Lint around motor causing it to retain heat
3. Vent system open at some point inside or behind case allowing heated air to remain in motor area
Follow the procedure below to disassemble and check interior of dryer. Vacuum carefully especially around and in the ends of the motor.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dryer will be on right.
Posted on Sep 11, 2009
Testimonial: "Sep 20, 2009 - Thanx alot for the response. Once inside the interior, I vacuumed around the motor and ends. Didn't seem especially built up with lint. After reassembling, did a few loads over a week or so with no problems. Now today, while drying, Wife opened the door to pull something out while still damp. When she closed the dryer and pressed the button to re-start....Nothing. Have waited over 45 min. and still won't start. Could it be something else? Thanx again"
  • 121 Answers
SOURCE: turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Posted on Sep 13, 2009
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
Gas dryer wont run
Hi. there can be many issue that can cause this type of interruption in normal operations. Lets go threw a few.One could be a faulty or dead motor. The timer board sends a signal to the motor once the start button is pushed. If the motor is malfunctioning or the wires that connect to the motor are lose or old and worn, the motor will usually click or buzz. the fault itself can be within the timer assembly or the motor itself. the best way to find out is to test the current flow at the motor by using a multimeter. connect this meter to the motor terminals and select the cycle and hit the start button. if the meter reads voltage at the motor and the motor clicks or buzzes, this will confirm an actual motor failure. if the voltage at the motor is weak or not there 0, this means the timer will need to be replaced. Next, I would check the door switch for its operational value. you can use the same method as i discussed above with the meter. use the terminals for testing on the switch. This could be a problem area as well. if the switch is malfunctioning, the dryer will not run at all. you will find the problem in one or both of the discussed areas above.
please rate and god bless.
Mar 25, 2009 | Kenmore Dryers
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Feb 02, 2009 | Dryers
Kenmore electric dryer model # 87670100
The motor is weak and needs replaced, don't hold the start button too long or you may smoke the motor's thermal protection and it could get smokey and stinky. Make sure you can get the blower wheel off before you make a run for parts, sometimes you have to break them off the shaft. : (
Sep 17, 2008 | Dryers
Kenmore dryer will not start
If the buzzing noise is from the vicinity of the switch, then suspect the push button contacts, if from within the bowels of the machine, then something is probably preventing the motor from running up to speed, it is stalled - (there are buzzes, and buzzes).This could be many things, from something mechanically jamming the drum, to worn bearings or a faulty motor/start circuit.
As I am not aware of your skills, I am not asking you to take the back off and have a look.
Jan 15, 2008 | Dryers
Dryers Logo
77 people viewed this question
Top Dryers Experts
