Question about Hoover Washing Machines
I put the machine on its gave huge bung noise and electric spark from back panel and cuts its electric supply. please help.
    Master:
  • 492 Answers
Sou d like you shorted the board. For safety please unplug machine and call a tech.
Posted on Oct 15, 2013
I have an amana tandem 7300... It does not do anything i turn it on it makes a buzzing noise....
First part any program is to activate pump to expel any water left from previous wash.sounds like something is blocking pump.coins/bra wire / hair bobble etc.if theres a flap at bottom of machine you ll find a bung behind to unscrew.water will come out! So tke drain hose from back and hold at ground level in a bucket etc then remove bung.u should be able to feel a plastic impeller(cross piece that turns) if it wont turn pullout what ever is stopping it.best to unplug machine first but quite safe to clear by hand.then put back bung and it should then work
Nov 22, 2015 | Amana Washing Machines
Run out of petrol on waters . Put 20Lt petrol in tank . Crank motor for a bit no go . No spark in plugs df150
Check switch in trunk fuel cut off switch see if you can reset it it may be your problem. if this was helpful please leave good feed back.
Jan 12, 2015 | Cars & Trucks
I have a haier 7 kg A+A it is saying error 7 can anyone help me with what the error is please
HOW TO FIX ERROR 7 PROBLEM! (Err 7 Means Motor Error)
This problem is quite common on these machines, especially just after the machine has been moved. It is usually because the electrical connector has become detached from the motor. Here is how to fix it.
* First of all, PLEASE unplug the machine from the wall socket! And switch off the water supply too!
* Pull the machine out from under the counter, and turn it so that you have access to the back of the machine.
* Remove the 3 phillips screws that secure the back plate. You are only removing the small plate immediately behind the drum, not the whole back panel!
* Look through the hole you have just created by removing the panel down towards the bottom of the machine. You will see the motor. Hopefully you will also see a 7 way connector not connected to anything, and a 7-way socket on the motor! (7 way means that it connects 7 different wires!)
* Plug the connector back on to the motor. Don't worry, it will only go one way round, so you can't get it wrong. If the connector looks like it is connected, give it a little wiggle and a push to make sure it is fully home.
* Replace the the small back panel, taking note that the top of the panel goes BEHIND the main back panel, and the bottom of it goes IN FRONT of the main panel. (This could be the other way round, I can't remember!)
* Push the machine back under the counter, making sure that it is level (level it up by turning the 2 feet at the front of the machine until it doesn't wobble), reconnect the water and plug it in to the electricity supply.
* Turn the machine on and attempt to operate the machine. (Top Tip: Select the wool or quick wash to test the machine, otherwise you will have to wait 3.5 hrs for the machine to go through a cotton/linen wash! Unplugging the machine won't help, because it remembers where it was when it gets a power cut!)
May 29, 2014 | Washing Machines
Thanks for taking my question,my sister gave me her 40"
Clicking noise and tv does not start. Most of the times it is the power supply board which is found defective. But I have found Main board also responsible for this problem. Please consult some qualified technician.
Aug 10, 2012 | Samsung LN-S4041D 40 in. LCD HDTV
My 2000 blazer (trailblazer package) has been cutting off recently. It seems like after driving it for about 30 minutes, it will cut off with no warning. It will start back if you let it sit for a few...
You would need to figure out if it is fuel or ignition related to proceed.
Someone would check for fuel pressure and spark when it stops running.
Could be the fuel pump relay, the ignition module, a crank sensor, or other things.
Jul 11, 2012 | Cars & Trucks
Zanussi Washing Machine - ZWF 14070W1 - Door Lock
If there is water still in the drum,try draining it out with the emergency drain hose down by the filter,then take out the filter bung by turning anti-clockwise and pull out to see what has got stuck in the pump.After this is cleared the door should open and the machine should be ready to run again.
Hope this helps.
May 25, 2010 | Zanussi ZWF14070 Front Load Washer
Mower made huge cloud of white smoek and shut off . mower was cutting off after 2 minutes, filled oil, replaced spark plug, changed fuel fitler. mower ran about 5 minutes, then made backfire noise and a...
Check for spark at the plug.
If the engine has points and condenser . check to see if the points are good.
If electronic ignition, then it is likely the ignition module is the cause
Aug 02, 2009 | Garden
Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
Oct 15, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hello - wondering if you can help - my packard bell U TOW-SAN computer gave a huge bang yesterday - blew the house fuse. When switched on again - it gave another huge bang and now refuses to switch...
Definitely the power supply. However, it could have damaged the motherboard as well but you won't know until you replace the power supply.
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Packard Bell Computers & Internet
Samsung washing machine
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Feb 13, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
