Question about Samsung ML2165W - ML-2165W Wireless Laser Printer
I have a Samsung ML2165w It will not print wireless only when connected to laptop. also when printing the last 4inches of the paper come out of the printer with the marks of the roller left on it ...
  • 120 Answers
Your roller has some problem. please contact your nearest samsung authorised service centre regarding this issue
Posted on Oct 18, 2013
Paper keep coming out wavy.. How can I fix that
"Wavy" paper is usually caused by something in the feed path catching. It can be lint build-up, dust or any number or things, including one or more rollers becoming too "slick" to feed the paper properly. My best suggestion is a vacuum cleaner, canned air and a good flashlight. Follow the user manual to remove as many of the serviceable parts (toner cartridge, drum, etc) as possible, cleaning each piece off with a dusting attachment. You do not want to blow toner around your home / office if it can be helped. Examine each part as you remove it to make sure it's normal. Look inside the printer along the paper path as much as you can; blow anything out using the canned air into the vacuum nozzle if practical.
The good / bad thing about the ML2165W is that they're easily replaced with something better if you can't get it working properly. Great excuse to go color laser or duplex printer.
Aug 29, 2016 | Samsung ML2165W - ML-2165W Wireless Laser...
Blinking lights
Check if it has paper stuck inside
Mar 29, 2015 | Samsung ML2165W - ML-2165W Wireless Laser...
How to change font size
The font size is determined by the document and the software, not the printer. If your printer is making the text a size different than that in the document, check your print settings to make sure that you have set the paper scale to something less than 100%.
Aug 23, 2014 | Samsung ML2165W - ML-2165W Wireless Laser...
How to connect wi-fi printer to laptop
With a wireless router that you probably have for you laptop. Printer should be connected directly to the router, and all PC's in you home can use it as a network printer, so everyone can print on it. Whether connection between printer and router is Wi-Fi or cable is of no importance.
The procedure of installation may be a little boggling for someone doing it the first time. As I remember you should start installing driver CD on you laptop, and it will tell you when to connect printer to it, and when the basic part of installation is over. This way you can use printer connected directly to you laptop via USB.
Next it will offer you to set wireless parameters. If your router is set to automatic (DHCP) it will ask you to register printer on your home network and you must enter your wireless network SSID and password somewhere in your printer. It should not be too hard. You just have to fallow the instructions.
If your friend comes over with a laptop and joins your wireless network, he still can't use your printer, because he's hasn't got drivers installed, so you'll have to do that part all over again, for every PC.
Oct 13, 2013 | Samsung ML2165W - ML-2165W Wireless Laser...
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
ML1865W offline
Try disconnecting the printer completely from power.
Reboot your system and re-connect the printer again.
Check for paper jams and clear them.
Delete any print queues.
Hope it helps.Thanks!
Jan 05, 2012 | Samsung ML1865W Laser Printer
When i print ,I get this error 'Manual Feeder Paper Empty
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Oct 06, 2010 | Samsung SCX4623F Laser All-in-One Printer
Samsung ML2165W - ML-2165W Wireless Laser Printer Logo
115 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
