Question about Canon imageRUNNER 1023iF Black and White Copier
Hi after cleaneing the copier with an air tool we found that all the images are copied but the paper is all dark i e the image is clear but a very high back ground
    Sniper:
  • 67 Answers
Probably blew toner dust into the laser unit, thats deep in the machine above your paper tray and behind the drum.
Posted on Apr 24, 2009
Image distort when copying and horizontal lines
Getting caught? Loose paper shred inside feeder?
Mar 28, 2014 | Canon D320 imageCLASS Digital Copier
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Jul 13, 2013 | Ricoh Aficio 1045 Black and White Copier
I have a Image Runner C3200 and it is tinting the paper black when making copies
- clean the laser units glass with the special cleaning tool provided with the copier
- check and clean the image transfer belt blade and the recycle mechanism
- check if the tinting is on the imaging unit , if yes change unit if not chevk above
Jul 27, 2012 | Canon imageRUNNER C3220 Color Copier
Copies come out perfect on the top of the page but the image is fades to almost nothing at the bottom of the page. Adjusting light/dark settings either bleeds out the whole image or causes Shading. What...
Have you changed the paper or flipped the paper over yet? Have you gone to add. funcations and go to cleaning and run the wire cleaning. Also, I would clean and replace all of the corona wires.
Aug 30, 2010 | Canon NP 6551 Black and White Copier
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
Fault code J50 & dark strip.
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
May 18, 2009 | Office Equipment & Supplies
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
Enhanced image
You have a problem in the fuser. Most likely the fuser roller is bad.
Mar 27, 2008 | Ricoh Aficio 450 Copier
AR 5316 VERY DARK BLACK COPIES
You need to check the drum unit for wear or the main charge assembly. If you are not mechanically inclined, just replace the drum unit and clean the transfer charge on the right side door.
Don't forget to rate your answers please.
Jan 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Canon imageRUNNER 1023iF Black and White Copier Logo
75 people viewed this question
old marine
old marine
