Question about SKB Corporation Skb Ps-45 Professional Powered Pedal Board W/hard Cover
Manual pdf no power to pedals how to replace fuse/breaker
Sanpera I amp pedal does not work consistently with peavey 30w amplifier
Either the cord is bad or more likely the jack needs to be resoldered or replaced.
Apr 07, 2014 | Peavey Sanpera I Amp Pedal
Brake lights are not working on my 1996 chevy s-10 pick-up
check if all brake lights are not working or not , if only one of em is faulty then its time to replace the bulbs . Else its just a blown fuse. Check users manual to find how to replace a fuse .
Thank you .
Jun 01, 2011 | Eminence Speaker Eminence PX:BULB...
Have BBE Acousimax pre-amp. Clip light is on and will not turn off. I have not power through the unit but power source seems ok. Fuse problem?
This device, unlike most guitar pedals, requires a 12 volt power supply. Are you sure yours is the original? If the supply is low, the internal electronics will show clipping. Make sure you are using the original power supply and if so, check the voltage it is producing.
May 16, 2011 | Bbe Acoustimax Sonic MaximizerPreamp Pedal
It seems to have no power the led light doesn't come on. its brand new, but I havent used it in about five years
Are you using battery or AC adapter for power?
Most pedals won't allow you to use both. Check that there is no battery installed if you're going to plug it in. If you are using a battery, Some pedals won't light an LED on battery power.
If problem persists, your pedal may be DOA
May 04, 2011 | Boss Mt 2 Metal Zone Effects Pedal
Power not turning on. yes i've checked the outlets, the connections and the breaker switches.
Most keyboards have fuses, and this could be the problem. If there is access to a fuse on the back panel, check to see if it is still good. If there is no fuse cap, then the internal power supply may have a blown fuse. If so, it's time to see a service tech...
Feb 10, 2011 | Yamaha P95 Digital Piano
NO power light from Digitech Vocalist 2 live. Power supply OK. Is there an internal fuse. etc? need tips to troubleshoot.
Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more.
Dec 23, 2010 | DIGITECH VOCALIST LIVE 2
Is there a circuit breaker
There should be a fuse holder near the place in the back of the amp where the power cord plugs in. Also some Marshalls have fuses in fuse holders on the circuit board. Always replace with the same value and type as the original fuse. Never open up the amp when it is plugged in to the outlet. When replacing the internal fuses do not touch the capacitors as they retain a lethal charge. If the fuse continually blows it is an indication of a more serious problem which will require servicing by a qualified repair person.
Jun 25, 2009 | Marshall Amplification Marshall MG250DFX...
The Distortion Pedal has no effect on the sound.
i got d same problm. i fixed it myself.. check all the op amp ic's if they're all gud. if youre not sure, replace all 4 rc4558 ic's. in my case, i still felt a very small output signal from my pedal (equalizers, vol n gain ctrls r gud since they vary when i change the setting) so i suspected that one or 2 of my ic's were damaged. i only replace d last two op amps which my signal passes thru. i also had this problm with my marshall drive master. same diagnosis and solution. check your schematics
Dec 14, 2008 | Boss Mt 2 Metal Zone Effects Pedal
SKB Corporation Skb Ps-45 Professional Powered Pedal Board W/hard Cover Logo
51 people viewed this question
Top SKB Music Experts
Vito Vacirca Jr.
Are you a SKB Music Expert? Answer questions, earn points and help others
