Question about Coleman 5040-751 BackHome Open Flame Patio Heater
Why it doesn't stay lit
Pilot lite won't stay lit. It lites up fine with a match but when you release knob to turn to flame it goes out
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Replace the gas valve or thermocoupler.
Posted on Oct 17, 2013
Buffalo12980
  • 625 Answers
SOURCE: wont stay lit
go to this site www dot desatech dot com. Here you'll find parts to repair your heater. a propane heater uses a millivolt generator to sense the flame. along it's cappilary are two push on spde connectors. these connect to the high limit temperature sensor which is mounted on the flame backplate of your heater. to see if it is the high limit shutting down your heater, jumper across the two spade connectors. if the heater stays on, this is your problem. if the flame still goes out, then the millivolt generator is shot.
Posted on Nov 10, 2007
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
SOURCE: I have a coleman evcon and the gas keeps shutting off
The click noise you hear is the magnet inside the valve dropping out. Which means, the voltage that energizes it is low or interupted. Possible, weak pilot flame, bad thermocouple or bad secondary limit switch. This limit switch is located left of the main control. made of ceramic. It can also be a bad gas valve...
Posted on Mar 27, 2009
johnsonr1
  • 91 Answers
SOURCE: The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Posted on Sep 12, 2009
atocrxr
  • 135 Answers
SOURCE: my coleman patio heater pilot lights but when I
Check the tip over senser,,, it is a plastic senser located under the screen, usually near the knob. It has 2 wires running to it, jumper them together and try it,, then order a new senser from the manufature.
Good Luck
Posted on Apr 04, 2010
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Laars lite 2 pilot
make sure gas pressure is correct if ok see if the silver tube has a cobweb also make sure all connections are good
Sep 04, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
How do I lite a wall room heater
First, turn off the gas valve for at least 5 min and ventilate the room. Most wall heaters are lit the same as a water heater. Find a red button to push or turn the gas valve knob to the pilot position. While pressing the red button or the gas valve knob, hold a match to light the pilot flame. After it lights continue holding the knob for one or two minutes. If the flame goes out when you release the knob the thermocouple is probably bad.
Oct 18, 2010 | Williams (5009622) Ceramic Gas Wall...
It wont lite, how do you lite the pilot, where is it located, do you have a manual i have a coleman presidental 3 furnace
There is a window directly above the gas control valve. Either a spring held latch or a screw off cover need to be removed to access the pilot. To light the pilot, turn the knob to pilot and hold down while lighting pilot. The pilot in straight back inside the hole about 10 inches. Use a long fireplace match or rig a wire to hold the match. Once the pilot lights, hold the control knob down for about 30 secs., if it stays lit after release, turn to "On" and operate normally.
Dec 13, 2009 | Tools & Hardware - Others
How do i start the pilot light on a JGBP28wek6ww
That model is an electronic ignition, ther isn't a standing pilot on it(no liitle flame that stays lit). Light the burner by pushing in on the knob and turnlig to "LITE" position, you will hear a clicking noise the sound of the electric spark igniting the burner, turn the knob to adjust the flame size. Keep in mind that all igniters spark whenever any of the knobs are turned to the "LITE" position. Good luck !
Nov 30, 2009 | Televison & Video
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
I HAVE MODEL GP30 WALL HEATER. I CAN LITE PILOT BUT WHEN I TURN CONTROL KNOB UP PILOT GOES OUT AND DOES NOT LITE HEATER
The thermocoupler is bad.Replace it,or if you can adjust it to where the thermocoupler is in the pilot flame.You know you have to hold the knob down for about 30 seconds or a minute,don`t you?If the flame will not touch the thermocoupler,it will not stay lit.You can cut a piece of copper tubing,or steel tubing to slidde over the old thermocoupler to make contact with the pilot flame,and it will work,if the thermocoupler is not in to bad of shape.
Oct 17, 2009 | Heating & Cooling
I am no repair guy and I can't see where to light the pilot? I am not keen on just strkiing a match and sticking it somewhere for the heck of it. What should I be seeing or what might it look like. It is...
Ok, throw the match at it> Just kidding. Right there at the main gas valve there should be a tube about 1/16 in diameter. It screws into the valve with a small brass fitting. Follow that tubing to its other end which goes into the burner . On the end of that is a bulb in a bracket. within a half inch or so of that bulb is the pilot flame or where the pilot flame is supposed to be, so push the pilot button down and get a lit match to that point and bingo.That bulb is a thermocoupler. It must get hot before you get main burner gas.so hold the pilot button down for a few minutes. Good Luck, Ned
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Canot locate remote swich or instructions how to get water heater pliot lit on 1984 itasca motorhome
look for the gas valve and on the top of it there should be a valve that has either off, pilot, or on. Turn it to pilot and depress the knob. At the same time follow the small tube that comes of the valve and at the end of it is the pilot burner. Hold a match to the pilot burner and when it lites keep on holding the knob down for about 20 seconds. If you can release the valve and the pilot stays lite then you can turn the knob on the gas valve to on.
Dec 21, 2008 | Heating & Cooling
Coleman 5040-751 BackHome Open Flame Patio Heater Logo
266 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
