Question about kawasaki Sport & Outdoor - Others
Starter does nothing and theres no headlights
    New Friend:
Https://www.dropbox.com/s/n7d10lthahzeoey/BMS_Pathfinder_owners.pdf This is the best I could find
Posted on Oct 15, 2013
Why does it seem as though my battery is completely dead but it isn't?
A bad cell could have too much internal resistance when the battery has to draw many amps to turn starter over. Put headlights on then hit the starter, if the headlights go off, the battery is bad or a connection at the battery cable or ground cable is dirty.
If you have a voltmeter, attach to battery and notice voltage of ~12v or greater, then hit starter, if battery is bad, the voltage will go from ~12v to under 9v and result is starter won't turn over the engine.
Feb 15, 2016 | 1998 Dodge Neon
I have a 1996 BMW 750 IL The battery is at full charge but when I turn the key to start there is nothing – lights are on seatbelt indicator on but no power to the starter can you help me with this
Turn on your headlights and try to start the car. If the headlights go from bright to dim or off , then the battery or it's connections are bad, or loose or corroded.
If the headlights stay bright, then the problem is likely the starter or it's connections.
Hope this helps.
Mar 29, 2015 | BMW 750 Cars & Trucks
Turn key lost all power
Clean and tighten battery cable connections and check battery ground, engine ground-should be a ground strap from engine to the body or frame. If this happens and you have nothing, no headlights, nothing-it's almost certainly a problem at or right off the battery.
Dec 26, 2013 | 1986 Ford Ranger 2WD
Put new battery ina1989 bronco 4by4 auto. still will not start unless i get a jump
If it is getting power to the starter when You are Not jumping it Then the starter ie going out.
Have a test light on the pos cable where it conects to the starter and have someone turn the key to the start position and the light should light up.If not test the starter silonoid.
Apr 05, 2012 | Ford Bronco Cars & Trucks
I have a 1996 chevy truck and with the key off my lights are on and my back light is on and when i try to start it there is nothing?
Is the lights being on draining the battery, if not then you have two problems, first check the lights, unplug connector from headlight switch and see if that turns lights off, if so then replace the headlight switch, next is the starting if battery is fully charged and nothing happens when key is turned then i would start by checking the starter, with a test light have someone hold the key in the start postion while you test starter, the back of the starter seliniod you will see two connections, one is a big connection with a battery cable going to it, that cable should have power at all times then theres a small connection next ti the big one with a small wire, thats the trigger wire that should have power when key is in the start postion, if theres power to both then replace the starter and thats the starting problem. good day.
Oct 23, 2011 | 1996 Chevrolet K1500
My 1995 toyota camry will not start just replaced battery and cables when I turn key nothing happens and nothing in the car will turn on except headlights
Hi and welcome to FixYa!
If that's the case then the problem can be on the starter itself. If you have replaced the battery but there's no click on the starter still then the problem can be on the starter solenoid or the starter gear is stuck.
I strongly suggest that you replace the starter for this can help start the vehicle. Hope this helps and thank you for using FixYa!
Have a good one!
Mar 29, 2011 | 1995 Toyota Camry
Headlights go dim when try to start,but nothing happen the switch lights come on but dont start. 1800 vtx motorcycle 2003
The headlight is supposed to turn off when you push the starter button. If you push the starter button and the solenoid clicks, the button is good. If there is no power going to the solenoid you can try disassembling and cleaning the button. Take a wire and jump the two posts on the solenoid or touch the two cables together. If your starter works, then you need a new solenoid. If you hold the starter button and tap on the starter with a plastic hammer and the starter works you need new starter brushes. Anything else wrong with the starter and you need to replace the starter assembly , unless the manufacturer sells replacement parts so you can repair the starter. most manufacturers only sell replacement starter brushes.
Feb 26, 2011 | Honda VTX 1800 Motorcycles
2006 honda shadow aero 750 has no power at the headlight plug. it has power at the fuse and the fuse is good but nothing at the headlight
Try cleaning the two position switch. It's called the starter button. You push it in halfway and the headlight turns off to allow for more juice to go to the starter. Push it in all the way and it activates the starter solenoid. It is probably either dirty or broken.
Sep 21, 2010 | 2005 Honda VT 750 Shadow Aero
2005 vtx 1300 wont start and has no headlight
Check regulator...this powers all running light tail lights etc.
Sep 01, 2009 | 2004 Honda VTX 1300 Retro
Sport & Outdoor - Others Logo
24 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
