Question about Braun 360° Complete Electric Shaver
Braun series 3 390cc will not charge It has a
Braun series 3 390cc will not charge It has a charge and works but does not show as charging when plugged in
  • 3,904 Answers
You state that is works here so other than the charging not showing I don't see a real problem here. If it drains totally and then does not recharge it is one of two things. Bad battery or bad charger. Replace the charging station first.
Posted on Oct 15, 2013
SOURCE: braun 6512 shaver stop working
hi i would say that you have major problem with this did you drop it sounds like a problem with the circuit contact braun or shavers uk kevin.
Posted on Dec 19, 2007
SOURCE: Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Posted on Aug 12, 2007
brector3
  • 1602 Answers
SOURCE: Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Posted on Jan 16, 2010
SOURCE: Braun Series 7 760cc dead after 2 months
Had this same problem with mine. One month after warranty was done with. I ended up opening the thing up and pulled the monster battery out of its socket and put it back in. Worked fine after that. One week and still strong. Another thing I did was to carefully bend up the flat pieces of copper around the battery to make sure they were still getting a good contact with the pins on the cover. Hope this works for you....
  1. The black rubber/plastic cover on the back will pop off if carefully pried apart from the gray plastic. Start around the middle of the razor body.
  2. Once the black piece is removed you will see four screws holding on a plastic cover. These can be removed with a sharp flat head screwdriver.
  3. The plastic cover can then be pried from the razor body. Be very careful though as there is a rubber seal around this to keep water out. I broke mine.
  4. Inside you will see a somewhat large red battery with prongs on either end. Pop it out of its location and wait a couple of seconds. Press it back into position and you should hear a click for both ends.
  5. After this, I took all of the flat copper pieces and gently bent them towards myself (without making them touch of course... this could cause a short and potentially cause the battery to explode).
  6. Replace everything and see how it works... Hopes this fixed it for you and saved you $100-200. Have a good day!
Also... I am not responsible for any damages that may occur.
Posted on Feb 02, 2010
brector3
  • 1602 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
The cleaning unit on my braun series 3 (350 cc-4)shaver will not work although it will charge after buying a new charging lead? Any ideas?
These cleaning systems are prone to many problems. If the shaver will charge directly from the cord but not the stand, your stand is faulty. They are not repairable since parts are not available. A new stand can be found at shaveroutlet.com if needed
Braun Clean Charge Base 5783 Fits Types 5772 5774
May 07, 2017 | Braun Health & Beauty
Reset light has appeared.What action is required ?
There is no Reset Light as far as I know and the manual seems to indicate the same. I have a series 5. The green light shines when you are using it. The red light flashes when the power in the battery is less than 20%. Put it on to charge and the light will flash green until it is fully charged and then the light will be solid green.
All of the manuals are here from Braun
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=subgrp&sgrp=subgrp&grp=SH01%3C%7C%3ESH02%3C%7C%3ESH03%3C%7C%3ESH04%3C%7C%3ESH08%3C%7C%3E&s=&subgrp=Series+7%2C+9000+series+-+Pulsonic%2FProsonic%2CActive+P
This manual page is showing the light indicators.
http://www.manualslib.com/manual/20437/Braun-Series-7-720.html?page=8#manual
Braun SERIES 7 720 User Manual Page 8
Apr 01, 2016 | Braun Series 7 720 Electric Rechargeable...
How to fix a Braun series 7 razor that will not charge in cleaning stand
Try plugging the cord directly into the shaver. If it charges this way, your clean and charge unit is bad. A replacement can be ordered from the link below
http://shaveroutlet.com/braun-pulsonic-clean-charge-base.html
May 27, 2014 | Braun 7000 Series Foil and Cutterblock
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
When I charge my Braun it does not charge.But sometimes it charge. I do not know what to do
i have series 3 wet and dry braun shaver when it ison charge it only sends ared light to show on grip never it blue charge what is possibly wrong
Feb 23, 2011 | Braun 4775 Smart Control3 Razor Series 3...
I cannot click the top on when i try to charge it ....
The latch on the 'arm' of the clean and charging base is broken. You can either change out the top portion of the clean/charge base or replace the whole thing if you don't thisnk you can do the repair.
Both itemsare available at shaveroutlet.com. See links below. Basic instructions for installing the top part are included on the item page
Sep 26, 2010 | Braun Syncro 7570 Electric Shaver
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Aug 27, 2010 | Braun Syncro 7526 Electric Shaver
Braun 5785 does not charge or auto clean via docking unit ?
HOW TO REFILL BRAUN  SELF CLEAN WITH JUST THE RIGHT BREW. THE MISSING INGREDIENT BRAUN DOES NOT WANT YOU TO KNOW
Mar 26, 2009 | Braun 4775 Electric Shaver
Braun 360° Complete Electric Shaver Logo
388 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
