Question about Keurig Coffee Makers & Espresso Machines
Do not know how to get automatic timer to shut off
  • 1,511 Answers
Press the AT button down for two seconds or more. It will go off or on accordingly.
Posted on Jan 30, 2014
I shut down my toshiba copier 282 in the right way . It gives me the message shutting down in progress but it doesn't shut down automatically as before. It only shuts down with the on/off switch
AD+206
Auto Shut Off Mode timer
setting (Auto Shut Off
Mode/Sleep Mode)
ALL Refer to
content
<0-20>
SYS Timer to turn OFF the
power or to enter the
Sleep Mode automatically
when the equipment
has not been
used
0: 3min. 1: 5min.
2: 10min. 3: 15min.
4: 20min. 5: 25min.
6: 30min. 7: 40min.
8: 50min. 9: 60min.
10: 70min.
11: 80min.
12: 90min.
13: 100min.
14: 110min.
15: 120min.
16: 150min.
17: 180min.
18: 210min.
19: 240min.
20: Not used
check this or update firmwear
Sep 29, 2016 | Toshiba Office Equipment & Supplies
I can't download the instruction manual from Intermatic's website. I have a EJ500C timer and want to know why they caution against using it with CFL's and how to program it to shut off...
EJ500 7-day or astronomic timer is incandescent light bulb timer.
Different timers have different Load ratings.
Intermatic ST01C timer can control CFLs.
Aube timers have same wiring capability as Intermatic, and offer CLF control, but you have to choose either astronomic timer, or 7-day timer.
Open following links for manual and timer information.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Aube-timers.html
Jul 16, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
It will not shut off. I also found that the elemet has break in it did not know if these issues are related.
If you timer does not move then its your timer. If you have the dryer on automatic then if could be your sensors not sensing the clothes being dry. They are not related.
Jul 13, 2011 | Dryers
Our 12 year old kitchenaide prestige dryer's timer gets stuck and it does not shut off automatically
Hi, If the dryer heats in the automatic cycle and the timer still does not advance, try using the time cycle. If the timer still won't advance, you will need to replace the timer.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
Feb 12, 2010 | Dryers
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Dryer automatically starts when the door is shut
Hello there:
This may not be just a timer issue this could be the door switch that is not operating correctly if this switch fails they will fail in the run position meaning the unit will want to run automatically when the door is closed
so what you are going to want to do is to try to remove the door switch and see if the dryer now runs if not there is the problem simply get a new one and reinstall it now if it is the timer you will have to remove the back panel the panel behind the knobs in the back it should have 8 screws
now after it is removed locate the timer it should be the one that controles the different time settings on the dryer. simply remopve the wires attached to it and mark them so you know where they go and get a new one and install and replace the wires and test if all is good than put the back cover back on ok
Hope this is very helpful for you
Best regards MIchael
Nov 27, 2009 | Kenmore Dryers
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
Lg 42' plasma tv shut it self on and off automatically
Sounds simple but check your sleep timer is off.
Dec 31, 2008 | LG 42PX5D 42 in. Plasma HDTV
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
PC automatically shuts down
Hi pank, Take a look at the BIOS setups in these machines. Business HPs and Dells have a setting to allow automatic shutdown and startup based on time. Another explanation is timer software; all of the computers I manage run a software timer that shuts down automatically at night. You might also want to talk to your network administrator since there are lots of management tools that allow remote shutdown of computer. It could be something they?re doing on purpose ?.. There are lots of other possibilities but I would check these out first since they?re more likely. Let us know how things go and please don't forget to rate the posting.
Jan 05, 2007 | HP Compaq dc7600 PC Desktop
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
