Question about Beam Industries 2900 Serenity Plus Central System Vacuum
Need to change the belt but can't get into the place where the belt is
  • Beam Industries Master
  • 3,904 Answers
You are just not looking hard enough for the fasteners to open this up. I am not familiar with this unit but I would guess there are screws holding it together the are usually concealed in deep channels. If you shine a light in them you should see the screw heads.
Posted on Oct 15, 2013
I need a diagram to show me where and how to install the front belt< I think the motor belt) on my Hoover Windtunnel, self propelled Model U6634-900 series x12-0 60HZ 120 V
Most vacuums are pretty well the same belt set-up...remove the metal plate covering the rotating floor brush and pull it out...place new belt over motor pulley and and stretch other end over rotating floor brush in the space provided for it....pull and place ends into slots on the sides....if the belt is not straight flip the brush the other way...you will figure it out. Just be sure to buy the right belt!!!
Regards,
Dennis
Aug 15, 2014 | Vacuums
HOW TO CHANGE A BELT
Hi there...You will need a Phillips screwdriver to get the bottom cover off.Remove the screws and then remove the bottom cover.Clean out any excess dirt in the general area of the roller bar and motor assembly area.Place one end of the belt over the steel shaft of the motor and then roll the other end of the belt on to the end of the roller bar.placing the belt on the top of the roller bar and roll the bar slowly and feed the belt onto the roller bar until it is completely in place.Replace the bottom cover and put all the screw back in.
Plug your vacuum in and turn it on with the roller bar off the floor, in other words let it run for 10 seconds until you put it on the carpet allowing the belt to position itself properly on the roller bar.
Jul 03, 2012 | Kenmore 31913 Progressive Direct Drive...
Have a bissell easy vac 3130-B and the brush on the bottom stopped turning i never looked before so i don really know if it turned in the first place
Behind the brush will be a metal thing that spins when the vacuum runs. That's what the belt loops over with the other end around the brush. You can sometimes find the belts a places like wal mart.
Aug 31, 2010 | Vacuums
What belt do I purchase for eureka whirlwind litespeed
If you have the exact model Eureka that this repair was listed under, model 4388 then please find a link to the belt you need below. If you'd like to verify the model number, please check the back or the bottom of the vacuum for a sticker that also will contain the serial number, and look for the word Model Number. If you don't have the 4388, please just add a comment with the model you have and I'll be more then happy to verify these two models take the same belt, or give you a link to the belt that goes to your model if they are different.
Here's a link to the exact belt called for on the model 4388:
Eureka Extended Life Style U Belt, Part 61120
Here's step by step instructions on how to replace the belt:
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor pulley when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor pulley.
6. Place belt around brush roll pulley.
7. Align left end cap with square in base. Push
end cap into place; see left side view.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
I hope this information was helpful to you in changing the belt. If you have any questions about how to change this belt, please just add a comment here on the repair page of Fixya, and I'll be happy to answer any follow up questions you might have. If you found this helpful, please be so kind and rate my repair helpful and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Metal Spring in Belt area?
Yes the metal spring is used to pivot one of the rollers in that area.
You would need to take it apart one more time and check to see if any of the roller travel up or down while you press it with your fingers. look to the edge on either side for a place to attach the end of a spring. then a place on the chassis to add the other end of the spring. Then redo the belt.
May 24, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Just need to know how to change the belt on my vacuum cleaner
place
end cap into base.
IMPORTANT
position belt.
two screws.
Dec 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Changing belt Please advise how to change the belt. I wasn't the person who took the belt off, didn't watch. Now it's just me and the belt. I had 2, but 1st one burnt right off. Apparently I didn't have...
place
end cap into base.
IMPORTANT
position belt.
two screws.
Belt
Not sure yet, but I assume you mean the belt that drives the brush at the base.
If it is an older style cleaner, there would a be cover held on by a few screws.
This hold the brush in place so tkae note of how it is in place should it fall out of place.
Lift the belt off the motor spindle to replaceit.
Sep 14, 2008 | Morphy Richards Vacuums
Eureka vacuum belt how do i replace on model #4688
touching the motor shaft when checking the belt.
5. Place new belt around motor shaft.
7. Align left end cap with base. Push end cap
securely into place.
11. Tighten screws.
You can goto this website enter in the model number 4688 and you can see detailed pictures of how to change the belt as well as print off a new user manual.
http://www.eureka.com/servlet/FindOwnersGuide
Regards
Feb 14, 2008 | Vacuums
Beam Industries 2900 Serenity Plus Central System Vacuum Logo
Top Beam Industries Vacuums Experts
Beamvacman
Level 1 Expert
Thatvacguy.com
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
