Question about Bosworth Sevcik, Otakar - Preparatory Studies In Double-Stopping Op 9. For Viola. Edited by Arnold. Bosworth
Hi, I`m interested to buy a book - Sevcik for Viola - Opus 9: Preparatory Studies in Double-Stopping (Sevcik Violin Studies)but I would like to know if it could send it to me in an digital format, like pdf Thank you Viorel Tudor, Spain arpeggione@ymail.com
I have an ancient Willy Wolf shoulder rest that was passed down to me. One side needs a new set screw and the sleeve is missing. Where can I buy new parts? The local hardware store says it's a...
It is not clear exactly what parts are missing. If you can find the screw or thumbscrew part, consider MAKING YOUR OWN sleeve...Possibly use a short length of copper tubing or cut a piece of rod and drill a hole in it for the sleeve... Sometimes for a spacer we have just stacked up several small nuts... better than spending $50 for whole new rest.
Sep 19, 2011 | Wolf Manufacturing Willy Wolf...
Shoulder rest measurment and ect.
If you get one of these for your viola it will fit,.. just make sure it is for a viola as the violin ones would be too small. There are several adjustments on this rest to play with
Sep 13, 2011 | MTX Bon Musica 16" Viola Shoulder Rest
I have a Prazision set and would like to know its value. It is an Orig Stark U931.
Around $10 to $15 per string in a set...The "S" suffix are usually the hard tension ones... need a good violin to take the tension.
Sep 07, 2011 | Thomastik-Infeld Violin Prazision D -...
Looking for owners/service manuals for a Yamaha SV-100 electric violin?
owners manual = http://www.manualowl.com/m/Yamaha/SV150/Manual/151436
Aug 30, 2011 | Yamaha SV-150 Silent Electric Practice...
I would like to buy a Barcus Berry 3100 for my violin... How Good is this coul you send me some ratings... Thanks
The Barcus berry range of transducers is well established and they are good quality. It depends on what you are doing with your fiddle! I use a K & K pickup on my double bass and its FANTASTIC. Check out their violin pickups - their kits is professional quality
http://www.kksound.com/violinissimo.html
http://www.kksound.com/violinissimo_pro.html
Good luck to you
Apr 01, 2011 | Barcus Berry 3100 Clamp-on Violin Bridge...
The d string on my yamaha ev 204 electric violin has no volume w/ the volume is turned up . Any suggestions?
Hello, what a great violin to own, I am jealous. Each string on your violin has a pickup sensor under it. So, what you have are 4 sensors (one for each string) and the signals are then fed into your violin's electronics and mixed there to provide a wonderful rich sound. The sensor under the D string has a problem. I would look there first and in the electronics package last. The best advice I can offer is this, I also am a musician and play violin and 12 string ovation guitar. I have worked on both my instruments, unless you are very skilled in your knowledge of electronics and the delicate work on the sensors on your violin, I would take it to a craftsman (person) that has the skills to change out the sensor. Sometimes it can be a bad solder connection in the electronics, especially with the vibrations that an instrument causes, again, this would be for someone extremely skilled in instrument repair.
Dec 24, 2010 | Yamaha Ev 204 Silent Electric Violin
Repair the boton of a violin, need to know what type of gue is used to join the baseto the side.
If you are gluing small pieces of metal to wood, or small pieces of wood to metal, we recommend:LePage's Metal EpoxyJ-B WeldFaststeel Epoxy Putty if you have gaps to fillIf you have a large amount of surface area, we recommend:LePage's Press-Tite Contact (solvent-based)LePage's Press-Tite Green Contact Cement3M Fastbond 30-NFtip.gifClamping can make the difference between success and failure here.tip.gif Whenever you are gluing metal it's a good idea to clean it first with steel wool or sandpaper. (Rust never sleeps.)
Mar 30, 2010 | Maxam Violin
Bosworth Sevcik, Otakar - Preparatory Studies In Double-Stopping Op 9. For Viola. Edited by Arnold. Bosworth Logo
29 people viewed this question
Top Bosworth Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Bosworth Music Expert? Answer questions, earn points and help others
