Question about Kodak EASYSHARE 5100 All-In-One Printer
My kodak esp 1.2 doesn't print straight so the paper jams all the time. It can't even pull the paper in with out jamming (even with one sheet of paper in)....
  • Kodak Master
  • 3,904 Answers
My guess it something is still stuck in the gears/spindles. Take this apart and do a thorough cleaning of all moving parts. This is not as hard as it seems but you will have to be patient finding all of the screws that hold it together. Take pictures as you dismantle in case you forget where everything goes
Posted on Oct 15, 2013
4 Suggested Answers
  • 285 Answers
SOURCE: error code 3820
try the baack of the printer. open it up from the back
Posted on Jan 28, 2009
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Posted on Apr 12, 2009
  • 295 Answers
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Posted on Jul 28, 2009
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
Paper jam on kodak pinter but no paper is in pinter and keeps saying paper jam
make sure to fan all sheets several times before loading, both from the 8.5" side, and also the 11" side. fixed my problem. hope it will fix yours
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Severs paper jam
Try turning the printer OFF wait 10 seconds then try carefully pulling the paper out. Then swith printer ON and let it sort itself out befor reloading with paper. Some times the printer gets greedy and takes in more then one sheet.
Jul 29, 2010 | Kodak ESP 5 Printer
Esp 5 all in one printe paper jam shows error. can't see where the paper is jammed. where do you start?
Go to www.kodak.com/go/itg and try the step by step solutions. If still you do not see the paper,call kodak @ 1800 421 6699 and they will replace the printer for you free of cost,even if Your printer is more than 1 year old,as all Kodak Esp printers are under warranty. Kodak is the best. Enjoy ,keep me posted.
Sep 25, 2009 | Kodak ESP 5 Printer
Kodak printer esp.3 ...paper jammed
Jul 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error paper jam
You should go to the website of whoever manufactures your printer. They always have drivers for their printers that you should be able to download and install in just a few minutes.
If you're absolutely, 100% sure that there is no paper jam, I would recommend just unplugging and restarting the printer.
Also, it may read a paper jam if you insert too much paper at one time. If you have a lot of paper installed in the printer, try taking out all but 10 sheets, and retry printing. My printer has a tray that accepts 150 sheets, but it "jams" if you put even close to that many in.
You should make sure that you aren't putting the paper too far in as well. Try pulling it back a few millimeters, as it may read a jam if the paper is pushed into the printing area.
Jun 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Apr 01, 2009 | Kodak ESP 5 Printer
Mar 19, 2009 | Kodak ESP 5 Printer
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
32 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
